Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: Visual and Spec Differences for Pistons - 67/68S, 69S, 906
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    I will take a stab at this, giving source info. Seems to be a confusing topic for the current active members on the forum
    Please help get this right if you feel you have an authoritative opinion...
    Let's start with some charts:
    Engine chart highlighting engines in question
    (source - B. Anderson's book):
    Name:  Porsche - 901 engine type 67_68S 69S 906.jpg
    Piston chart with some CR, P/N errors and maybe others (e.g. 906 piston numbers)
    (source - http://www.early911sregistry.org/for...l=1#post459256)
    Some previous discussions on same topic:
    69S P/Cs
    http://www.pbase.com/9146gt/my9146gt...9_911s_pistons
    906 P/Cs
    http://www.pbase.com/9146gt/my9146gt...cylinders_set1
    Background discussion from April 2010
    http://www.early911sregistry.org/for...-ID-Pistons...
    Another from Sept 2010
    http://www.early911sregistry.org/for...ston-Corrosion
    Recently
    http://www.early911sregistry.org/for...of-906-pistons
    1969 S Coupe #761
    Early S Registry #1624
    Aug 2009
    Atlanta
    69S Piston
    Source pics:
    Quote:
    "The 69S piston has noticeable straight sides to the valve pocket. The 67-68 S piston has round valve pockets. Thats the easiest way to tell the difference."
    http://www.early911sregistry.org/for...l=1#post459487
    Based on the assembled pics in these posts, the larger intake valve pocket on the 69S piston is very noticeable when shown against a 67-68S piston, as well as the 'straight sides' to the valve pockets as quoted above.
    69S Piston identified by 80P26E
    Name:  69S Piston top.jpg
    Name:  69S Piston bottom.jpg
    Name:  69S piston side.jpg
    In the side view it is clear this piston is probably no longer usable. But still a decent reference for profile view.
    1969 S Coupe #761
    Aug 2009
    Atlanta
    67-68S Piston
    Source pics:
    http://www.early911sregistry.org/for...rs-and-Pistons
    http://www.early911sregistry.org/for...68-911S-piston
    Notice the top edge of the piston at the intake/exhaust overlap ridge and compare it to the 69S in the above post.
    67/68S Piston identified by 80P25E (needs source reference in form of pic/thread)
    Name:  68S piston top.jpg
    Name:  68S piston side view.jpg
    Name:  68S Ps and Cs.jpg
    1969 S Coupe #761
    Aug 2009
    Atlanta
    906 Piston
    Source pics:
    http://www.early911sregistry.org/for...l=1#post480032
    906 Piston identified by 80P26 or 5? or 80P25+ and some accounts of 80P26E
    The chart in first post above may contain error (906 = 80P26)
    Some debate over holes drilled under piston dome and around wrist pin boss, and whether or not that was done to all 906 pistons
    Name:  906 Piston top.JPG
    Name:  906 Piston bottom2.jpg
    Name:  906 Piston side view1.jpg
    Name:  906 Piston side view2.jpg
    1969 S Coupe #761
    Aug 2009
    Atlanta
    906 - 2 ring Piston
    Source pics:
    http://www.early911sregistry.org/for...l=1#post414905
    906 Piston identified by 80P26 or 80P25+
    Name:  906 2 ring top.jpg
    Name:  906 2 ring side view.jpg
    1969 S Coupe #761
    Aug 2009
    Atlanta
    I am not comfortable yet with the chart showing piston numbers mapping to their respective applications.
    My quick research shows that there are too many discrepancies out there. Lots of misinformation and confusion.
    1969 S Coupe #761
    Here is a picture of later Mahle 67/68S set (Nikasil). 9.8 to 1 CR, 160 hp.
    But the valve pockets look squarer than the originals. Is there a reason for this?
    Aug 2009
    Atlanta
    blue72s,
    Thanks for the post.
    Is there a number on the underside of the piston? Curious if Mahle is even using the numbers in the chart above.
    I don't know the answer to your question but the valve pockets appear 'squarer' than original 68S pistons.
    Anyone...
    1969 S Coupe #761
    Quote Originally Posted by beh911 View Post
    The pic is not mine. I downloaded from the web.
    For ages, I have been trying to find answers about the squarer valve pockets but to no avail. My guess is that the pockets are '69S spec (diameter, not depth).
  1. Italian Spec vs US Spec 911S?
    By 73ess in forum General Info
    Last Post: 01-14-2014, 03:10 AM
  2. Replies: 1
    Last Post: 05-25-2010, 04:43 PM
  3. Replies: 3
    Last Post: 04-14-2009, 02:05 PM
  4. Engine Spec. Differences
    By delire in forum Technical Info
    Last Post: 04-26-2002, 06:15 PM
