Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: 1971 911 Dashboard differences
  1. #11
    Quote Originally Posted by dirk07 View Post
    The replacement has only tree studs on there passenger side, cause the manufacturer uses the same form for the later dashes with the air vent, where the forth stud is at the earlier dashes.
    The dash I installed is NOT a replacement dash. It is an original Porsche dash removed from another 911 of an unknown year. Fits perfectly, except the location of the farthest outward mounting stud on the passenger side did not line up with the hole on the metal dash frame. I had to drill a new hole (on the other side of the rectangular access hole in the metal dash frame) towards passengers door.
  2. #12
    Senior Member dirk07's Avatar
    Apr 2016
    Stuttgart, Germany
    Your second picture shows clearly a modern production replacement dash. Can´t follow this discussion any longer.
  3. #13
    Quote Originally Posted by CheckBookChuck View Post
    I think you should remove the pic of the dash you did not use and leave your words to describe differences
    If I understand correctly you think you have 2 old dashes the one you removed from your car and the one you got from another car and fitted to your car.
    One is different to the other 3 studs v 4 studs may I suggest the 3 stud version is not as old as you may think
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
  4. #14
    The original dash from my 1971 911 has four equally spaced mounting studs that go thru the dash on the drivers side. My replacement dad only has 3 studs, and the one in the far right closest to the passenger door down not line up with that last hole. Was there a dash change somewhere in the ‘69 - ‘73 range?
    Bump. I took out the generic replacement dash photo as my newly installed dash was not a replacement but rather a used OEM dash removed from another 911 of an undetermined year.
  5. #15
    Senior Member rgupta250's Avatar
    Jul 2020
    Orange County, CA
    Unsubscribed.
    1971 911T/ restoring to S-spec Coupe / Gold Metallic on Black
    1995 911 C2 / Guards Red on Cashmere Beige (Sold)
