Thread: Pistons for Nikasil and Cast iron Cylinders
    Junior Member
    Sep 2022
    Does anyone know how the piston to cylinder wall clearance varies from a aluminium nikasil cylinder to a cast iron cylinder?
    The two types of cylinders would expand quite different amounts as they heat up
    I suspect that if you put a piston designed for a nikasil cylinder in the same size cast iron cylinder it will be too tight after it heats up.
    Better over here ...
    Senior Member matteo68's Avatar
    Jul 2021
    Wootton, Woodstock, UK
    I’m confused about this frequent ‘Better over here’ comment? Do you mean here as in the USA or here as in ESR, rather than Pelican, Rennlist or DDK?
    ESR #4098
    ‘72 T Coupe (donor car for M491 2.5 SR)
    '72 S Coupe (2-owner tangerine unicorn)
    'Better over here' meaning the poster posted this thread in our 'Other Porsche Passions' forum.
    With his question I thought it better over here in our 'Technical Info' forum....
    Jul 2021
    Ah, I see. Thanks for the clarification Chuck!
    ESR #4098
