Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: rear fuse panel
  1. #11
    Jun 2012
    London, Ontario, Canada
    Quote Originally Posted by BOYER73S View Post
    When was your S built Ravi?
    Feb 1973
    Ravi
    Early 911S Registry # 2395
  2. #12
    Yours should have wingnuts just in case you have knurled screws.
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
  3. #13
    Jun 2012
    I have wingnuts. We had the discussion on the board during by build. But the consensus was there would be no cover on the 3 fuse holder back there if I recall.
    Ravi
  4. #14
    Correct Ravi
    Clyde Boyer
  5. #15
    Mar 2016
    U.K.
    I don't believe there was a sticker, the fuse info is embedded on the inside of the cover if memory serves me right.
    My May 73 build has a rear engine cover with this imprinted format. I can load a photo if it helps. It is secured by wing nuts.
    Kind regards
    Gitesh
  6. #16
    Yes I have seen those too much better idea than paper that falls off due to heat.
    Clyde Boyer
  7. #17
    Apr 2012
    Simi Valley Ca
    '69S, pretty much the same as Boyers picture, except no Amperage designations. Just in case you have never seen one.
    Very important, don't EVER loose one of those screws! 4.5 mm X .75 pitch and a rounded end. You will never find one of those, and will end up buying another fuse panel to get one.
    Bob B
