Results 1 to 10 of 20
Thread: Sound deadening 1973
    Jun 2012
    London, Ontario, Canada
    What's the current thinking of sound deadening for the floor pans for 72-73? I have the original insulation in the rear tub/parcel shelf etc. and no rust under it whatsoever. SO that's all good. On the floors I also have no rust but we chipped away some of the tar stuff with the hexagonal imprint at places where it had cracked to check for rust. All looked good, but now I have a few sections of bare metal where we did scraping (including almost all of the driver's side pan) and the remainder with the original black material. I've used POR15 over the bare metal but am wondering what I should do on top of that? Just leave it? Use rubberized coatings like Wurth etc? Or use some kind of modern audio or vibration damping material? What to people think?
    Ravi
    Early 911S Registry # 2395
    Nov 2010
    Darien, CT
    These seem to be popular with full resto crowd. Was the way we are leaning with our 69 resto.
    http://www.repaintsupply.com/3m-0884...ads-p6102.html
    3M 08840
    Scott
    69 911S #1379
    65 356 SC #130757
    Senior Member csbush's Avatar
    Jan 2009
    San Antonio Texas
    That 3M pad is what I am using in my 73 restoration. I think it is important to help absorb road noise. It does lay down nicely, and fits the contours of the floor pan. It looks about as original as I have seen- unlike dynamat and other sound deadening. They also look very similar to the replacement pads from Porsche I was able to buy in the mid 80’s when I replaced the sound deadening on my 70 911.
    Chuck
    Early 911S registry #380
    '70S
    '75S
    '96 C4S
    '65 R69S
    Jun 2012
    Thank you both. I hadn’t seen that product, but it turns out it is made in the 3M factory right here in town, so I can support a “local” business.
    Ravi
    EDIT: For future reference, NAPA carries this in the US and Canada.
    Jun 2012
    For reference.
    Jun 2015
    Connecticut
    Like this.
Size:  118.4 KBName:  P1050291.jpg
    Thanks Scott72 for the tip.
    J P
    69 911T 2.4L w' 2.2S/E cams/Webers
    Jul 2006
    Corvallis, OR
    Wurth also makes the similar adhesive backed materiel. I just wish they didn't put the diamond stamped texture on the top.
    72S, 72T now ST
    Jan 2009
    San Antonio Texas
    The other part of the sound proofing is the sound deadening pad that goes between the tar stuff on the floor and the carpets/floor mats. I know this was on my 73 T because I have pieces that were glued to the floor. Here is a picture of one from the back seat area:
    I went to an upholstey supply store and got a roll of this carpet padding. Cut to shape and glued to the floor it looks like this:
    Not sure if this is exactly correct, but I matched the original best I could. It will help cut down noise and make the floor carpeting more comfortable on my feet.
    Chuck
    '70S
    '75S
    '96 C4S
    '65 R69S
    I went large and the difference is DRAMATIC.
    Don't care about the weight, not that much. I can now have a conversation with my passenger, listen to bluetooth and not have ears ringing after hours of driving.
    With new carpet padding and carpet, you'll notice the difference in comfort. Doubt you'll notice the performance "loss due to the weight gain"
    [SIGPIC][/SIGPIC]
    Ray Crawford
    Early S Registry #271
    R Gruppe #255
    '70 911 S Coupe 2.9 w/MFI Twin Plug "Flairs n Chairs"
    '72 911 S Targa 2.4 w/MFI
    Feb 2012
    Sweden
    Quote Originally Posted by RC70SCoupe View Post
    Out of curiosity, what was the weight gain?
    -70 911E
    -84 3,2 Sold
