Page 1 of 18 12311 ... LastLast
Results 1 to 10 of 178
Thread: Reference: 380MM steering wheels - THE TRUTH
    There is much confusion, deception, out and out lies, myths and misinformation about 380MM steering wheels.
    I will attempt to solve some of them.
    First of all, not all 380mm wheels are alike and most of them are not appropriate for a 911 or 912 but they will fit, sort of.
    The only true "380mm Carrera RS" wheels come from 70 and 71 914s. 914/4s and 914/6s use the same wheel in 70 and 71. 70 and 71 914/4s have a bunch of plastic on the back of the wheel to adapt it to the 914/4 steering column and turn signal switch. 914/6s use the same parts as a 911 on the back of the wheel.
    The first picture is the back side of a 72 or later 914/4 steering wheel.
    The next picture is the back side of a 70/71 914 steering wheel with the plastic junk removed.
    The next picture is of a 72 or later 914 steering wheel with the plastic removed.
    Do you notice any differences?
    They are significant!
    The splines are the same and both will fit on a 911 steering shaft. The later 914 wheel could possibly suffer if the wheel nut gets over tightened, though. Not a problem with the early 914 wheel.
    Ciao
    I thought it was already clarified for good ...
    http://www.early911sregistry.org/for...Wheel-stand-up
    Instagram
    Twitter
    Part 2
    Now, lets examine the back side of the hub where the horn canceler goes. Notice that the surface is perfectly flat around the edge of the late 914 wheel and is raised on the 70/71 wheel. Now look what happens when you attach the horn canceler. Yes, it sticks out on the late wheel and fits perfectly on the early wheel. Also, when attaching the horn canceler to the late wheel, one must drill new holes and then countersink them. They are already there on the early wheel.
    Quote Originally Posted by Biancaneve View Post
    There still seems to be some confusion and I may be just adding to that. That thread has some very good info but you have to read page after page to get it.
    You can bear with me or just not read my drivel.
    More info and awareness is always good
    Instagram
    Twitter
    Senior Member mohrgan's Avatar
    May 2011
    Upstate NY
    Jim,
    You seem to have answered some of my questions in a couple of posts. I have read many threads regarding this topic and some of them just don't go anywhere. These pics and your explanation are concise and to the point. Thanks!
    -Chris Mohr
    S Registry #1978
    The front side of 914 steering wheels. If it has a countersunk area around the splines, it is a late wheel and came from a 72 or later 914/4 no matter what the seller says! You can not hide the counter sunk area in a picture. The "good 914/4 wheels are flat on the front.
    The first version of the counter sunk wheels has sharp edges and does have a lip around where the turn signal canceler goes, much like the early 914 wheels and all 911 wheels.
    The later versions have beveled edges and are flat on the back.
    Part numbers on 914 wheels
    914 347 805 10................... Leather covered, rubber rimmed steering wheel 70/71 914/4 and 914/6 and physically the same as 73 Carrera RSs. (The best choice for 911s) These are the ones
    that are flat on the front.
    914 347 806 10...................Consensus choice as the correct 73 Carrera RS 380MM steering wheel
    914 347 803 10................... Plastic rimmed 70/71 914/4 steering wheel (You can cover these in leather and they work just fine. Double wrap them and they are even better)
    914 347 805 11....................Leather covered 72 914/4 steering wheel (with 90 degree counter sink) Not the best choice but they do work better than the later 914/4 wheels with the
    beveled counter sink.
    914 347 804 11....................Plastic rimmed late 914/4 wheel
    914 347 809 00....................74 and later 914/4 "simulated leather" wheels. These things are junk!
    Bottom line.........................If it is flat on the front it is best and if it is beveled it will work but not great
    Luft gekuhlt Bummler's Avatar
    May 2005
    The Valley...
    How about this one stamped 10-69?
    Attachment 254805
    Stefan Josef Koch
    RGruppe #194/SRegistry #1063
    1969 Porsche 911E, Light Ivory (38 years and counting)
    2015 Porsche Cayman S
    2012 BMW R1200GS, 1973 BMW R75/5
    "An intelligent man is sometimes forced to be drunk to spend time with his fools." -E. Hemingway
    Quote Originally Posted by Bummler View Post
    Attachment 254805
    A genuine 1970 914/6 leather covered steering wheel?
    Thanks for the picture.
    I would welcome any additions to my post.
    Now, please tell me what it is.
  1. FS: 380MM Carrera RS Steering wheels.
    By WES914 in forum For Sale: 911 Parts
    Last Post: 06-29-2013, 10:33 AM
  2. FS: 380mm Steering wheels 914.347.804.10
    By gms in forum For Sale: 911 Parts
    Last Post: 05-05-2011, 06:36 AM
  3. Questions about 380mm steering wheels
    By Cornpanzer in forum Technical Info
    Last Post: 04-17-2011, 02:37 AM
  4. 2 380mm RS type steering wheels
    By Rennman in forum For Sale: 911 Parts
    Last Post: 05-01-2010, 03:44 PM
  5. FS 380mm Steering wheels, batwing, more
    By Allen Henderson in forum For Sale: 911 Parts
    Last Post: 01-15-2008, 06:25 AM
