Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 32
Thread: Behr 2.8 RSR Oil Cooler
  1. #21
    Daren or anyone, do u know what connections were used for the oil line hookup. Straight, 90* fitting or banjo w/hollow bolt? And did the oil hoses always come into the front trunk thru the top of the inner fender? Gordon
  2. #22
    Hi Gled
    Banjo with hollow bolt,i can send you a pic of one if you want.
    Yes through the top of the inner wing on a 2.8
    Best
    Paul H
  3. #23
    If u don’t want to post it here, I’m at early911s@aol.com. Gordon
  4. #24
    Mar 2007
    Melbourne, AUS
    Great news Darren!
    It’s a Festivus miracle
    Member #3508
    1973 911 2.4T
    1976 911S -> 2.8RSR replica
  5. #25
    Quote Originally Posted by Yellow491 View Post
    Hi Gled
    Best
    Paul H
    I will take a photo tomorrow,we can also get these copied at 100%,they have a very thin hex head.
  6. #26
    Costings will be in the new year.
  7. #27
    Thanks, interesting bolts
  8. #28
    Senior Member Darren65's Avatar
    Thunderbirds are Go!......
    I guess these things are seldom straight forward and it has taken a while but pleased to report that this project is full steam ahead and Paul and I will soon be offering what we believe is a truly authentic reproduction of the 2.8RSR and 914/6GT oil cooler.
    To be certain the modelling of Paul's NOS oil cooler was accurate 3D printed prototype were produced and the results are pretty damn good........castings of the end tanks and brackets have now been commissioned, the cores ordered and we hope fabrication will commence in the next couple of months
    As with the 3.0 coolers these will come with the correct pressure relief valve and be alocrom coated and a bolt on ready to go product.
    Here's progress to date.....
  9. #29
    Getting Close....
    Things are getting ever closer with the first castings now received. All has come out perfectly and a full batch are now being produced.
    This is the final piece of the jigsaw, the cores have been manufactured and we'll be able to start production in the next couple of months
    Obviously the castings below still need machining but this basically the components that will make up the finished coolers......
  10. #30
    Aug 2013
    AZ, UK, FR
    Outstanding work!!!
    first ride - 10 yrs old in a 73 911S - Silver - I was done for
    Started 'playing' with them in the late 80s
    Started racing a 72 911 T built to 2.9L RSR in SoCal SCCA, PCA, POC early 90s
    Have owned over 50 long hoods from late 80s until 2000
    dropped out from 2000 - 2018 - due to life, work, travel
    Been building a 2.8 'RSR' inspired car since 2018 - 9111121235
    http://forums.pelicanparts.com/porsc...1121235-a.html
