Page 6 of 30 FirstFirst ... 4567816 ... LastLast
Results 51 to 60 of 297
Thread: The Bob Joyce thread!: Restoration of a 1968 911 L Targa
  1. #51
    Aug 2017
    el sobrante ca.
    took advantage of a nice bay area afternoon and shot the clear on the quarter panels...
    (Maybe i should have jumped on a bus to Reno .... not a single bug or other foreign object landed in the clear!).
    The reason i am painting things in pieces and with the doors wide open is because my body can't tolerate the atmosphere...
    So far .... this works for me....
    I chose the PPG water base for this reason, but the jobber could not mix this Light Ivory in any other single stage paint any way...
    Ironically ... If I had shot, this car with single stage I would have been done 6 months ago ....
Size:  94.7 KBName:  DSCN1231.jpg
  2. #52
    Aug 2017
    el sobrante ca.
    Final prime for front passenger fender...
  3. #53
    Aug 2017
    el sobrante ca.
    Final prime for the driver front fender....
    this will (hopefully) be the last part to paint....Name:  DSCN1241.jpg
  4. #54
    Aug 2017
    el sobrante ca.
    warm enough (plus, i put the paint cans out in the sun to warm up) to shoot the clear on the passenger front fender...Name:  DSCN1243.jpg
Size:  86.0 KBName:  DSCN1242.jpg
  5. #55
    Dec 2013
    Connecticut/Florida
    Great thread.
    1971 911S Coupe - Gemini Blue
  6. #56
    Aug 2017
    el sobrante ca.
    while i was waiting for paint to dry....
    It was pointed out by a 912 Registry Member from across the pond that the Restoration Design front slam panel for the 1968 had an irregular shape
    Because the car is already painted i decided to cut a piece off of my original 1968 Targa latch support ang graft it in....
    Name:  DSCN1244 - Copy.jpg
Size:  53.8 KBName:  DSCN1246.jpg
Size:  28.0 KBName:  DSCN1245.jpg
  7. #57
    Aug 2017
    el sobrante ca.
    For St. pat's day... The final car part painted and clear coated.
    Now I will allowName:  DSCN1255.jpg
Size:  102.0 KB the finish to settle and then shoot another clear coat on the intire car.....
  8. #58
    Can’t wait to see the finished product!
  9. #59
    Aug 2017
    el sobrante ca.
    This is the first part to get the final clear coat...
    The driver side rear bumper
  10. #60
    Aug 2017
    el sobrante ca.
    Final clear coats for front bumper and gas tank door...
    Special Note: I have accepted the reality that hanging the clear out all the way will be way too risky due to fly's/debris etc.
    I will color sand a little more and buff a little more and still achieve my desired finish
Size:  87.5 KBName:  DSCN1260.jpg
Size:  91.7 KBName:  DSCN1261.jpg
