Page 17 of 18 FirstFirst ... 715161718 LastLast
Results 161 to 170 of 178
Thread: Reference: 380MM steering wheels - THE TRUTH
  1. #161
    Were the 806.10 wheels just standard wrap? Or thick? I see people thick-gripping the lookalike 805.10 wheels but I'm unsure of how the original RS wheels were wrapped.
  2. #162
    Senior Member rgupta250's Avatar
    Jul 2020
    Orange County, CA
    I believe the original RS wheel (806.10) was just leather wrapped and not padded.
    Best,
    Ravi
    1971 911T/ restoring to S-spec Coupe / Gold Metallic on Black
    1995 911 C2 / Guards Red on Cashmere Beige (Sold)
  3. #163
    Jul 2020
    Orange County, CA
    Quote Originally Posted by matteo68 View Post
    What is the correct rim girth for a thick-covered wheel please?
    Thanks.
    Cruisingnkali is correct; it should be 3 5/8”. I have a 380mm wheel rewrapped by Dallas Steering Wheel and it measure exactly 3 3/4” and it’s unused. Over time and with exposure to the elements, it should shrink to 3 5/8”.
    Best,
    Ravi
  4. #164
    Senior Member matteo68's Avatar
    Jul 2021
    Bicester, UK
    Great thanks, that’s a real help.
    ESR #4098
    ‘72 T Coupe (donor car for M491 2.5 SR)
    '72 S Coupe (2-owner tangerine unicorn)
    Looking for 915/00 gearbox #7120023
  5. #165
    RS Steering Wheel
    Steering us right guys,
    We believe the answers above are only half correct. An RS Steering wheel has NO extra padding like an original RSR wheel. The photos below are of an original RSR wheel we own. The grip is about 3 5/8. You can see the padding on the plastic wheel itself and the thin lining on the leather grip of the original wheel. Don redid our wheel keeping and repairing the original padding on the plastic rim of the wheel. An RS wheel does not have this padding. I do not recall the circumference of an original RS wheel but it is about 3 inches. It will feel "thin" compared to today's steering wheels in cars. Searching this forum will give us a confirmed number for a standard 911 leather wrapped wheel, which is the same as a standard RS wheel. From the link below where "andyjboy" wrote: Just measured the circumference of the leather grip on both an 806.10 & an 805.11 - both have their original leather covering & both measure 7.6 cm" (3 inches)
    See this thread:
    https://www.early911sregistry.org/fo...ng+wheel+stand
    -Allen-
  6. #166
    Quote Originally Posted by LiveFromNY View Post
    John, You are correct. The 806.10 is the same thickness as the 805.10 wheel (and 400m standard leather wrapped wheel) and are about 3 inches (thin). They are the SAME wheel except for the part number. Neither an
    805.10 or 806.10 are thick grip wheels. See answer above for more info. Thanks.
    -Allen-
    In Austin until 2022.
  7. #167
    Mar 2017
    Orange County, CA & Tucson, AZ
    I had my 805.10 wheel re-wrapped by Tony at Autobahn and the circumference measures 3.5"
    Curious, if these are thick wrapped with padding, do you still feel the 'finger grip' along the back? I can still feel this and I like it -- feels a bit vintage to me.
    Bill
    Instagram: @myflat6
    '72T hotrod 210 0228
    '82SC Targa
  8. #168
    Will an 804.10 bolt directly up to a 911 if the plastic junk is removed?
  9. #169
    Quote Originally Posted by Gideon911 View Post
    Yes……………..
  10. #170
    Yes……………..
    Awesome thanks! Wasn’t sure because someone talked about needing a 30mm spacer with his 804.10 on page 9 of this thread. I wonder if he didn’t remove the plastic
  1. FS: 380MM Carrera RS Steering wheels.
    By WES914 in forum For Sale: 911 Parts
    Last Post: 06-29-2013, 10:33 AM
  2. FS: 380mm Steering wheels 914.347.804.10
    By gms in forum For Sale: 911 Parts
    Last Post: 05-05-2011, 06:36 AM
  3. Questions about 380mm steering wheels
    By Cornpanzer in forum Technical Info
    Last Post: 04-17-2011, 02:37 AM
  4. 2 380mm RS type steering wheels
    By Rennman in forum For Sale: 911 Parts
    Last Post: 05-01-2010, 03:44 PM
  5. FS 380mm Steering wheels, batwing, more
    By Allen Henderson in forum For Sale: 911 Parts
    Last Post: 01-15-2008, 06:25 AM
