Results 1 to 5 of 5
Thread: battery drained by charge control lamp?
    Senior Member moito's Avatar
    AUSTRIA (tu felix)
    i`m not the graetest when it comes to troubles with the electrical system of a 911.
    a friend of mine has a 73,5 targa.
    since a few days the charge control light goes on when the key is removed from the switch (us car with non locking switch) and drains the battery
    the light goes off as it should once the engine is running.
    any ideas?
    Senior Member dirk07's Avatar
    Apr 2016
    Stuttgart, Germany
    The diode in the wiring between handbrake light and alternator light might be defect.
    Apr 2004
    35,000 ft
    It varies. Often the diode is on the back of the alternator. When it fails it will keep the charging light on with the key off.
    Feb 2010
    San Francisco, CA
    Quote Originally Posted by blucille View Post
    This sounds like the culprit. I had the same issue and it went away when I swapped for a rebuilt alternator.
    E911SR & RGRUPPE
    '73 S Coupe #306
    AUSTRIA (tu felix)
    thanks much guys---will forward the info to her(yes her)...and report once the problem is solved.
    franz
