Results 1 to 10 of 28
Thread: Trick to installing headlights?
Hybrid View
    Atlanta, GA
    What is the trick to installing headlights in my 66 Porsche. I have a new gasket and the bucket is really tight. Got it installed, but not sure it's correct or well seated. Also, could not figure out how to install the new HL bucket screw I got from Eric with the small rubber spacer he includes. I understand the reason for it, but getting it in? Thanks Mark
    Mark Erbesfield
    1973 911S #9113301282
    1957 356A #58648
    1982 Toyota Land Cruiser FJ40
    1977 Toyota Land Cruiser FJ40
    1979 MB 450SL "Dad's old car"
    2019 Cayenne "Wife's car"
    Feb 2007
    San Diego
    THere are 2 types of headlight seals - thin and thick. Porsche parts guys only supply the thicker one, International Mercantile supplys the thin one which is supposed to be for early cars however many early cars have had the headlight bucket replaced or changed so the thicker seal could be needed if that is so. Stock 66 headlight buckets that have not been messed with should take the thin seal.
    The rubber spacer is not for the retaining screw as a spacer, it is meant to replace the receptacle for the adjustment hook, I think if I am talking about the same part.
    Atlanta, GA
    Quote Originally Posted by VintageExcellen View Post
    Well this must be the "TRICK" using the correct seal. I bought my HL seal from another supplier and it is the thick variety. So I need a thinner seal and HL should seat well. Thanks.
    Mark Erbesfield
    1957 356A #58648
    On LWB cars there is a particular orientation for the sealing ring, but I forget what it is...
    An important trick is to use some big zip ties to hold in the very expensive and NLA H1s in case they pop loose.
    Porsche did a lousy job of design on the headlight retention.
    Feb 2007
    San Diego
    The design for holding the headlights in is not that lousy, in the long run this type of design does not hold up to fender benders/rust/bad bodywork. It is very important to fit the headlights you are going to use before the car is painted. If the car is virgin then the lights usually go right on and stay on. If the headlight bucket has been replaced then there is a good chance that the light will not pop over the lip or the lip is not the right shape to hold the light in place or there could be a gap.
    And yes what a pain, balancing expensive H1 headlights over the ground as you hope they fit in place. Then drive the car and hope they never come loose!
    Oct 2010
    Florida
    It's a lousy design. It never worked. When I go track day i always tape the headlight in place with the stupid blue tape. Back in the day the rally guys would build a little bracket for holding the trim ring to the fender.
    I actually fabricated some brackets for my car and then couldn't bring myself to drill holes in the fender and trim rings. Oh well.
    Richard Newton
    Car Tech Stuff
  1. Replies: 16
    Last Post: 07-25-2017, 06:15 AM
  2. Replies: 4
    Last Post: 08-19-2013, 06:10 PM
  3. smog test trick
    By Fritz A. Ficke in forum Technical Info
    Last Post: 08-28-2005, 08:40 PM
  4. one trick donkey...(or something like that)
    By Homemade 911 in forum General Info
    Last Post: 10-29-2004, 11:39 AM
