Thread: Normal leak down numbers for 2.4S engine
    May 2008
    Sydney
    Hi All,
    I am in the process of stripping down my car, and as I am going through it, questions are popping up, and I do have a curious mind
    i looked under the rear engine lid and saw these numbers.....guessing these are leak down numbers, so wondering what are the normal numbers for a freshly rebuilt engine as opposed to an older engine or even when is it a good idea to rebuild an engine. I am going to rebuild the engine, at some stage, but i am just curious
    These are the numbers as per the picture below, sorry dont have any other numbers
    115 135
    115 130
    120 125
    Name:  Porsche updated photos 035.jpg
    Clayton Shipard
    Sydney, NSW Australia
    1972 911 2.4S
    2000 Boxster S
    Those are cranking compression numbers, not leak down. The more even the better, in a perfect world they would all be 135. While not great numbers they're not bad enough to warrant a rebuild. Of course you don't know when they were done.
    May 2008
    Sydney
    Thanks edmayo,
    And sorry for my ignorance......I will have to look at the engine in due course, but this might be a little indication of possibly rebuilding further down the track. Which might help depending on how i am tracking budget wise, but again i will revisit further down the track.
    thanks again for your help.
    Clayton Shipard
    1972 911 2.4S
    2000 Boxster S
    Senior Member SpawnyWhippet's Avatar
    Mar 2013
    San Francisco Bay Area
    I've just done my first ever leak down test on my 1972 2.4T. It took me so long that the engine was pretty cool by the time I finished, so the numbers are probably all over the place. I had particular difficulty getting the hose threaded into cylinder 6, took me 60 mins.
    These are my results:
    1. 26% (6% when retested again at end with colder engine)
    2. 16%
    3. 14% (was very difficult for me to find the dead center for this one, readings varied between 38% and 14%)
    4. 30%
    5. 6%
    6. 16%
    All my plugs were very sooty, and the engine is not pulling as strongly as I'd like (mind you, even my 2004 Turbo doesn't do that). I am not entirely confident all the results are accurate, as sometimes the lowest figures were not obtained when the timing marks were aligned on the pulley.
    Any recommendations gratefully received on further testing, or should I retest again on a hot engine now that I know how to do it?
    Member # 2899
    1972 911T
    2004 996 C4S
    2001 996 Carrera
    2008 Cayenne S (sold)
    2004 Cayenne Turbo (sold)
    2009 997 cabriolet (sold)
    2002 996 Turbo (sold)
    1998 Boxster S (sold)
    1997 993 cab (sold)
    1989 911 3.2 Carrera (sold)
  1. Normal Engine Temperature?
    By merbesfield in forum Technical Info
    Last Post: Today, 11:36 AM
  2. FS: 1967 911 normal engine- complete
    By TRE Cup in forum For Sale: 911 Parts
    Last Post: 02-23-2014, 10:57 PM
  3. Recommendations- Best engine cleaner after oil leak
    By Haasman in forum Technical Info
    Last Post: 05-23-2013, 05:23 AM
  4. 2.2T compression/leak numbers
    By jetdriver21 in forum Technical Info
    Last Post: 12-30-2007, 11:16 AM
