Page 4 of 11 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 106
Thread: The starting of the stripping process
  1. #31
    Port Macquarie, Australia
    Prostitch in Sydney can also do your dash. The owner is a 911 owner and supplies all of the interior textiles (vinyls, carpets, fabrics).
    John Forcier
    EarlyS #1987
    Restoration Saga
  2. #32
    May 2008
    Sydney
    Thanks Chris for the Dr Dash referral.
    Thanks John for Prostitch, Funnily enough I just got off the phone with a mate who was referred to Prostitch to recover some 968 CS seats in leather. I will give them a call.
    Clayton Shipard
    Sydney, NSW Australia
    1972 911 2.4S
    2000 Boxster S
  3. #33
    Prostitch is the upholstery part, and Classic British and German is the textile supply part of the same business... http://www.classicbritishgerman.com.au/
    John Forcier
    EarlyS #1987
    Restoration Saga
  4. #34
    May 2008
    Sydney
    Thanks John,
    That website looks like a great little site for future reference......once the car is stripped, rust removed and then painted the reassembling will begin. As with all projects there is a budget in mind so this may extend the time frame depending on things.
    Clayton Shipard
    1972 911 2.4S
    2000 Boxster S
  5. #35
    May 2008
    Sydney
    My Brother gave me a hand today........and yes the engine and gearbox are now out. I am thrilled the engine is out and quiet surprised that the engine and gearbox came out so easily.
    Clayton Shipard
    1972 911 2.4S
    2000 Boxster S
  6. #36
    May 2008
    Sydney
    So i had a bit more time to work on the car today, i removed the rear engine cover, removed the rear electrics, remove the rear trailing arms, removed the head liner, and even had a quick look at the front struts. The front struts ended up having orange BOGE struts in them, so will now have to look at what to replace them with for future, but thats down the track.
    I haven't remove the loom yet was looking at it and thought i would ask what is the best way to remove it. Do i just pull it all forward from the rear and out in the center of the car ? or do i disconnect as much as possible and pull it backwards and out the rear of the car ?
    Below are the photos
    Clayton Shipard
    1972 911 2.4S
    2000 Boxster S
  7. #37
    May 2008
    Sydney
    Clayton Shipard
    1972 911 2.4S
    2000 Boxster S
  8. #38
    May 2008
    Sydney
    Had a bit more time to work on the car, pulled out the windscreen wipers and dials, and pulled out the sunroof. Also started to remove the rear torsion bars, only got the 4 bolt spring plate covers off. So was thinking whats the easiest way to remove the rear torsion bar ?
    Also with rear trailing arms, what is better ? powder coating or just cleaning them up and preparing them to be painted black again ?
    sorry no photos as phone went flat before i could take them.
    Clayton Shipard
    1972 911 2.4S
    2000 Boxster S
  9. #39
    May 2008
    Sydney
    thought i would add a few photos, these are for future reference for the wiring of the dials as i took these just before i pulled the dials out. I taped the wires together in bunches for each dial. fingers cross this works and helps me when i put them back in.
    Clayton Shipard
    1972 911 2.4S
    2000 Boxster S
  10. #40
    May 2008
    Sydney
    one more
    one for inspiration
    I will take some more of the dash and what i have since done shortly
    Clayton Shipard
    1972 911 2.4S
    2000 Boxster S
  1. Magic rechrome process
    By adam912 in forum Technical Info
    Last Post: 10-02-2012, 02:24 PM
  2. Stripping, dipping and Ecoating
    By nick-moss in forum Technical Info
    Last Post: 08-05-2012, 07:38 PM
  3. Stripping Undercoating Need Ideas Please
    By FHernand in forum General Info
    Last Post: 11-26-2006, 10:01 AM
  4. New PCA COA process
    By pu911rsr in forum General Info
    Last Post: 10-20-2006, 04:53 AM
  5. Signal Color Process
    By rsr1975 in forum General Info
    Last Post: 01-31-2006, 07:19 AM
