Page 9 of 9 FirstFirst ... 789
Results 81 to 89 of 89
Thread: Dual Battery Options
  1. #81
    I just put an Anti-Gravity L-i battery in my VW Golf TDI - 32# weight reduction. Expensive!
  2. #82
    Dec 2009
    Copenhagen, Denmark
    Quote Originally Posted by ejboyd5 View Post
    What are you guys/girls doing that make batteries such a problem? My '69 Karmann coupe has a Sears Die Hard Group 58 battery that cost $49.99 when I installed it on October 1, 2002. No leakage or other problems during 15 years, 11 months of service. No trickle charger or battery tender ever used. The only modification employed to give this long life is a battery cut-off switch that totally isolates the battery when the car is not in daily use.
    Would love to see a pic of your batter cut off switch.
    James Hurst #1638
    R Gruppe #514
  3. #83
    Dec 2010
    Southold, NY
    Nothing more than the simple Hella disconnect switch with a removable red handle. It's located in the smuggler's box and wired to isolate the negative battery terminal from the body ground.
  4. #84
    Feb 2005
    Montreal, Canada
    FYI ; The latest batteries from Sonnenschein are now black instead of grey ; even better !
    Same batteries, I just changed the sticker on the right one (got it from a member in the classified section)
    Perfect fit, perfect look and dry batteries !
    I got them at 171$ CDN each plus shipping ( about 130 USD, that's a great deal !!)
    Call Matt, tell him JD from Montreal refer you.
    Advanced Battery Systems Inc
    Burlington, ON., Canada
    tel. 905-681-8227
    www.advancedbattery.ca
    JD
    1970S Coupe, Blood orange #1436
    1965 Coupe, Dolphin gray #1506
    R Gruppe #647 ; S Registry #1666
  5. #85
    Apr 2011
    N.Calif., south of SF
    hey that's great to hear. Where did you find the sticker?
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
  6. #86
    Feb 2005
    Montreal, Canada
    Can find it, but it’s a member in the registry here who reproduced them a while back...
    JD
  7. #87
    Jun 2012
    London, Ontario, Canada
    That's a great price JD. Shipping should be cheap as they are just up the road from me. I just bought 2 Odyssey 925 batteries which I was going to make fake cases for :-( Probably can resell them though.
    As for stickers, this place sells a lot of relevant ones. I got the Varta ones. https://www.isaydingdong.co.uk/ourshop/
    Robert Gross makes the DETA ones, but good luck getting ahold of him.
    Early 911S Registry # 2395
  8. #88
    Mar 2016
    U.K.
    That's a great price. The DETA, Bosch, Varta round stickers look great but the battery strap covers most of them, which is a bit of a shame. I think the Porsche Moll sticker looks great.
  9. #89
    Jun 2012
    Inspired by Ed and with JD's observation that Sonnenscheins are now black.
    The right Deta stickers are also now available at https://www.isaydingdong.co.uk/oursh...Volt-90mm.html
    I just liked the 3D profile of the Varta label.
    Ravi
Size:  119.3 KBName:  A8903A2F-B9A3-40FE-B2BA-C0FF02E055E5.jpg
  1. FS: Early 911 dual battery positive connection cable
    By MountainRoads in forum For Sale: 911 Parts
    Last Post: 03-11-2013, 06:29 AM
  2. WTB - Dual in/Dual Out muffler...
    By Rookie_912 in forum For Sale: 911 Parts
    Last Post: 06-29-2012, 06:59 AM
  3. Are these switches for dual fuel pumps or dual ignition?
    By JPlonghood in forum General Info
    Last Post: 10-08-2009, 07:17 AM
  4. Converting from single battery, back to dual
    By kenikh in forum Technical Info
    Last Post: 06-28-2006, 08:56 PM
  5. 1967 battery options
    By Keith Newby in forum Technical Info
    Last Post: 05-15-2003, 01:26 PM
Tags for this Thread
