Results 1 to 7 of 7
Thread: Correct carrera rs muffler
    Does anyone know if Liestritz was the oem muffler for the 73 rs?
    RGruppe member 445
    Lightbulb
    As far as I've learned, for the most part yes....
    However, I believe Bischoff also had at least part of the contract. As far as I can tell they were identical except for the name.
    I have seen Bischoff Early mufflers with '70's date codes.
    Someone?
    Feb 2003
    Los Angeles
    I had an original Bischoff muffler on my very original, barn find 1972 911T with a 1972 date stamp. It had too many holes from sitting, so I had to replace it.
    Bert Jayasekera
    1970 911T - Tangerine Orange
    Early 911S Registry #494
    R Gruppe #167
    Chuck/Bert- Thank you. Since either could be correct, would I want one over the other as far as quality, fit, sound,,,,,
    RGruppe member 445
    I found a Bischoff. The part number is 901. 011. 08/ 170 and in another area says 901/1.
    Is this the correct one for the rs?
    RGruppe member 445
    Can you post a pic John, the number sounds correct ...
    The Bischoff and Liestritz were pretty identical (same spec/contract, different vender)
    Leistritz
    Here's the Leistritz that I found + put on my '70 . . .
  1. New Product! Correct muffler tip....
    By Soterik in forum General Info
    Last Post: 07-19-2023, 06:46 AM
  2. Correct muffler color
    By Nicklasliljegren in forum Technical Info
    Last Post: 05-17-2013, 02:25 PM
  3. Correct muffler for early 911
    By mfitton in forum Technical Info
    Last Post: 08-30-2011, 12:03 PM
  4. Correct Muffler for '73
    By Jay Laifman in forum General Info
    Last Post: 03-24-2009, 08:06 AM
  5. Correct finish for Webasto muffler?
    By Flunder in forum Technical Info
    Last Post: 12-01-2008, 08:48 AM
