Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: Change to MFI pump on 2.0 s motor
  1. #21
    Apr 2012
    Simi Valley Ca
    Frankr,
    Apparently Kenik posted above that Supertech sells an adapter to fit 2.2 cut heads to the 2.0 barrels.
    Call Supertech, Henry will probably answer the phone and give you all the info you need.
    BTW, have you priced a set of 2.0S Mahle pistons lately? Very hard to find and VERY expensive. Maybe best to go the 84 JE direction, and try and keep the CR around 9.5:1. When I rebuilt my engine in 1982 (It still sits in my garage in the car, never started) I paid $600 for the 2.2S set, and could have had the 2.0S for the same price.
    Bob B
  2. #22
    Jun 2013
    lynchburg, Va
    Yes for new 2.0 Mahle set $5K or so at least. I might look at some other alts now. I prefer not to use JE pistons. Like checking for any valve issues and then having pump reset to 2.2 specs. Bruce A's book indicated you only lose about half a point in compression so going from nearly 10 to 9.5:10 is not that bad and might be pref with today's gas It is very strong up to that 6200 or so RPM range--then runs out of poop.
  3. #23
    Apr 2012
    Simi Valley Ca
    Frankr,
    Are you sure about that compression figure? Someone that replied to my post said about 7.5:1. You are only getting about 33cc of extra displacement in each cyl. with the 84mm pistons, and the dome is very flat. I would want to assemble 1 cylinder with the head, put it at TDC and measure the combustion chamber with a burette. Fill the chamber to the bottom of the spark plug hole. Then you know exactly what you have, no guess work. If you do this, let me know what you come up with.
    Bob B
  1. WTT: complete 1970 2.2 T motor for running 71 2.2 motor
    By rliberty in forum Free, Trades, and Swaps
    Last Post: 03-27-2014, 03:51 PM
  2. WTT: 1968L Aluminum Case 901/14 Motor for 1969 911E 2.0 MFI Motor
    By LouieLargo in forum Free, Trades, and Swaps
    Last Post: 05-18-2013, 09:01 PM
  3. FS: 2.8 motor parts, heads, pump, and stacks
    By PJenkins in forum For Sale: 911 Parts
    Last Post: 06-27-2008, 06:37 AM
  4. '65 Rebuilt Motor And Trani / '70s Motor On Ebay
    By JPlonghood in forum For Sale: 911 Parts
    Last Post: 01-23-2008, 04:37 AM
  5. Replies: 14
    Last Post: 10-25-2006, 01:09 PM
