Good detective work,great find!
Makes it all worth while.
S Registry#2021
John Forcier
EarlyS #1987
Restoration Saga
Well, CONGRATULATIONS. Since they are both aluminum cases, there will be date codes on the side of the main case near the diff cover. There are also casting part #'s there, the last digits give the revision. Please look for any other markings that may indicate the LSD was original; some people report a stamped "Z". Photos would be most useful. Knowing the actual gears would be interesting to see if the boxes have been updated. 904 mainshaft would be a bonus. You may be stuck with the Nadella shafts unless there is something special to adapt the ZF LSD to use CV joints available.
John,
These are both 911 transmissions by serial number, but the one pictured on a stand has a 912 front mount.
Thanks Dave and Jon, your assistance has been invaluable.
Both boxes are very dirty and need a good scrub; which is a job for next weekend. But I will dust off my good camera and take photos of everything, as well as trying to find any relevant numbers/stamps.
I thought the gearbox cross member from the S was odd - I thought it may have been a "targa thing"
So far, so good. My knee-jerk purchases have uncovered a real S Targa, a real S engine (not correct for the targa though), some proper RS flares, a very straight rust free L coupe, and two useful gearboxes... Now I just need to put the money I pinched out of my kid's school fund back and promise my wife "not to do it again", and I'll be good
John Forcier
EarlyS #1987
Restoration Saga
Brilliant stuff Jon B! That's exactly how it is... I wonder what the advantage/disadvantage to having no pre-load is?
Thanks again.
John Forcier
EarlyS #1987
Restoration Saga
Diffs without preload don't wear down their clutches as quickly, and allow cars to turn more easily at low speeds. For long-term street use these are important factors.
Jon B.
Vista, CA
Can anyone tell me what this is ?
902-16 #5191720
Woody
