Results 1 to 10 of 10
Thread: Correct muffler color
    Senior Member Nicklasliljegren's Avatar
    Jul 2012
    Stockholm
    I´ve just purchased a correct stock muffler to my 911E from 1969. The muffler is in rather good condition, except for some minor dings and the fact that its missing almost all of its original paint. The dings will be no problem. But I´m not sure whats the correct color and I am in desperate need of some good tips.
    Best regards
    Nick
    Feb 2010
    San Francisco, CA
    E911SR & RGRUPPE
    '73 S Coupe #306
    Jul 2012
    Stockholm
    Thanks for the help Kent. Now I know what color the muffler should have.
    A further issue that emerged is about the muffler bands should be painted the same color as the muffler?
    / Regards Nick
    Senior Member Per Schroeder's Avatar
    Mar 2013
    Avon Lake, Ohio
    Since that thread, we've released this stuff:
    http://stoddard.com/shop/shopexd.asp?id=62244
    Per Schroeder
    Jul 2006
    Washington D.C
    Very nice. How do we use it (primer, heat cured, etc.)?
    Quote Originally Posted by Per Schroeder View Post
    Andy (VA).
    Nick, you will find the muffler bands in two varieties;
    stainless steel - just scotch bright it (polish if you must).
    or Silver zink plate.
    If the zink is showing rust a quick sand blast and coat with what ever you think looks like silver.
    VHT even has has a clear if the zink cleans up.
    Or sent them out for replating.
    Bob
    Early S Reg #370
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    Quote Originally Posted by Nicklasliljegren View Post
    / Regards Nick
    It certainly looks better when the bands are not painted along with the muffler, IMO. I would leave them in their natural plating
    1969 S Coupe #761
    Early S Registry #1624
    Mar 2013
    Avon Lake, Ohio
    We recommend it over a bead blasted part. No primer. Spray it on and let it dry naturally overnight. At that point, you can either bake it at 400 for 30 minutes in the oven, or just bolt the part on the car and run it for the same time--let it cool and it should be good.
    Quote Originally Posted by flatsixcrazy View Post
    Per Schroeder
    Jul 2012
    Stockholm
    Txh Bob and Beh911
    / Nick
    Feb 2007
    San Diego
    VHT paint on some exchangers and muffler. THe dark grey is more correct and was no available last time I tried to buy it. The lighter grey primer is on the exchangers and looks better than a silver alternative. VHT stays on with very high exhaust heat, not much else works as well.
  1. New Product! Correct muffler tip....
    By Soterik in forum General Info
    Last Post: 07-19-2023, 06:46 AM
  2. Correct carrera rs muffler
    Last Post: 06-27-2013, 09:00 PM
  3. Correct Muffler for '73
    By Jay Laifman in forum General Info
    Last Post: 03-24-2009, 08:06 AM
  4. Muffler strap color?
    By Kaleid in forum Technical Info
    Last Post: 01-07-2007, 10:51 AM
  5. Dansk sport muffler color
    By Shawn in forum General Info
    Last Post: 09-25-2004, 09:46 AM
