Thread: How are YOUR CV Joints?
    Apr 2011
    N.Calif., south of SF
    Started hearing an intermittent grating noise from the left rear. Then it disappeared.... Then started occurring with increased frequency. The "little voice" in the back of my head said "check your CV joints". Wow .... nasty!
    Since I do not have an in depth service history on the 73, I pulled both axels.
    This was the worst CV joint.
    Long time ago, when I worked in service for a summer, I saw the results of a failed half-shaft flail around on the underside of a 911. Basically took out part of the engine, transmission, trailing arm, brake lines, oh and modified the body like I had never seen before.
    In reflection I had been driving my fast and hard ..... believing all was good..... I'm in the process of replacing all four since all were either pitted and/or scored.
    How are YOUR CV joints?
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    Jun 2011
    Mound, Louisiana
    You have to be an idiot to run one until it fails. They give plenty of warning! Mine are redone and awaiting installation.
    Paul Harrop 12.5% German.
    Early S #2059
    Feb 2010
    San Francisco, CA
    Those were indeed doomed to fail. Good intuition on checking them!
    Better safe than sorry.
    E911SR & RGRUPPE
    '73 S Coupe #306
  1. FS: SWB Ball Joints Used
    By jhora in forum For Sale: 911 Parts
    Last Post: 11-16-2010, 06:17 PM
  2. Ball joints
    By MrJTP2001 in forum Technical Info
    Last Post: 08-11-2009, 01:31 AM
  3. CV Joints
    By 356robo in forum Technical Info
    Last Post: 04-03-2009, 07:07 PM
