Results 1 to 8 of 8
Thread: Just got my COA
    Banned
    Nov 2012
    The OHio
    Just got my COA
    My 68 911 has a gearbox 901/04
    What the heck is that?
    Apr 2011
    N.Calif., south of SF
    It would seem that the factory believes your car was produced with a 901 gear box that had 4 gears forward.
    Haasman
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    Banned
    Nov 2012
    The OHio
    strange Haasman
    Quote Originally Posted by Haasman View Post
    Haasman
    Oct 2008
    Burford, ON, Canada
    I have not seen that one before. What is the serial #? Then I would check the transmission itself. The numbers are on the bottom rib under the case. It is odd that I have not come across this one before.
    Dec 2008
    Woodland Hills, CA
    COA is probably wrong...
    My COA quotes the correct trans number (found on the trans) it is a conventional 5 speed unit. Although the COA calls is a sporto! Keith
    Banned
    Nov 2012
    The OHio
    3080147 901/04
    Oct 2008
    Burford, ON, Canada
    According to this, it is a 902/0, however I would not trust that completely. Please check the numbers on the transmission case to verify.
