I goofed around with backdating a new Brumos frame.. I personally like a frame to appear around the year the car it is.. before you drop some coin buy a few old frames... try to do it yourself. The chrome paint at Home Depot really works well and you can get the other paint supplies at a hobby store.
Registry # 2479
1970 T Tangerine
1972 T Albert Blue
The enemy of good is better. Leave the chrome alone and touch up the paint.
.........Very well said........................................
1968 911S
1986 Carrera
2006 Carrera S
I have used chrome paint on different projects... scotch brite whatever you are painting then I usually clean up with acetone and prime it and chrome it... main thing is the shake the life out of the can to get good coverage.. start spraying a foot away from item and at medium tempo swipe across it.. 2 passes then wait.. then shake again... above was done with a combo of a brillo pad, acetone, q tips, 800 grit sandpaper. I put a few scratches in it to make it look old.
Registry # 2479
1970 T Tangerine
1972 T Albert Blue
Dropped-off a frame for restoration by Charles Sihilling Metal Finishing in Santa Ana, CA
I had considered doing a ‘test-run’ w/ a not-so-special/-tweaked frame . . . but the work I’ve seen so far looks more-than-acceptable. Save myself some $
And so, the toughest part has been picking a frame to restore. Most of the ones that I have are well-used --- and I like them fine . . . which is why I got them in the first place. The few that could use some repair/resto are a mixed bag of wear + bends + breaks + etc. The worst might be a bit challenging --- re: $$$ . . . to bring back. Plus? On some --- I have no idea what they’re supposed to look like
The frame that I chose is an early ‘70s Allred. Nice frame --- big panel RWB &Co, in un-restored condition --- still has some of its original paint . . . but beat. Lotsa little tweaks + bends --- but no breaks. Also, not a lot of detailing to get goofed-up by plating. I figure this will need a lot of ‘metal-finishing’ vs –repairing/-replacement
Anyway, went by the store, showed + told + placed my order. I specifically requested that I be contacted after all the metalwork gets done --- and prior to any chrome being applied --- to see how the re-finishing looks . . . but I also want to talk about the plating
No shiny/heavy/flashy ‘show chrome’ on this. I want as thin a kiss o’ chrome as these Guys can manage = ‘flash-chrome’
Also --- painting is not done by Sihilling . . . they farm it out. Not surprising, but I’d still like to meet The Painter. If worse comes to worse? --- I can do it myself: compressor + air-brush + years mixing paints + building models. Should be straight-forward . . . dull blue lettering + dull white back-round
Stay tuned . . .
Very interested in your results, I'm in the final stage of restoring an original 'early' Vasek Polak Manhattan Beach license plate.
The way it was...
After the blast... (and pot-metal weld-repair)
More photos here
subscribed...
