Page 1 of 12 12311 ... LastLast
Results 1 to 10 of 117
Thread: Door Seals
    Door Seals
    Bought some new reproductions of the original style seals a couple of years ago and finally got around to installing them.
    Not a hard job but they are like handling an octopus. Soon as you think you have them set and ready to measure for cutting they fall out of place. Start over.
    What is needed:
    Update: 9.18.12 The factory didn't likely make a mitre cut based on observations. I'll call this "dealers choice". It's pretty but it's not the way it was done.
    Cheap plastic mitre box or a good eye for a 45º cut. "Eye Ball" not good so cheap box stood in.
    A long razor blade or very sharp knife for the mitre cut.
    3M Black Weatherstrip adhesive.
    Door Panel tools (use of the blade ends is pretty handy in setting the B Pillar section of the seal; photo attached 2 tools starting 2nd from left)
    Super Glue to bond the ends at the 45º cut.
    Patience is a virtue. Take your time. It's a boring job but you really want to measure a couple of times before cutting.
    I didn't shoot photos of the operation because… well, I just didn't find it all that exciting.
    I did one side yesterday and then rode 4 motorcycles. That's not a necessary step but it was fun.
    Finished the other side today after making my 45º cut on the passenger side seal last night and letting it set up overnight.
    Buttoned it up this afternoon and went for a ride in the old SL.
    Looks like it should and the doors do shut a bit easier now that the "tubes" are gone.
    Tom
    Early S Registry #235
    rgruppe #111
    Feb 2003
    Los Angeles
    Hi Tom,
    Thanks for the write up. Any reduction in wind noise with this style door seals?
    Bert
    Bert Jayasekera
    1970 911T - Tangerine Orange
    Early 911S Registry #494
    R Gruppe #167
    It's pretty quiet in the garage.
    There wasn't an opportunity to test it yesterday. I'll report back as soon as possible.
    Tom
    rgruppe #111
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    Can you post a picture of the seal? I'm curious what the profile looks like as there have been a few iterations of these.
    1969 S Coupe #761
    Early S Registry #1624
    Full and Cross Section. The rubber is quite dense and nearly as hard to handle as a black snake! It won't stay where you want it unless the area is tight (like the threshold and B Pillar).
    This is where the tools come in handy because there is a groove in the rubber that needs to be slipped under the threshold and B-Pillar channels.
    I glued it a short section at a time and once satisfied everything was where it needed to be shut the door and walked away.
    Tom
    rgruppe #111
    Aug 2009
    Atlanta
    Thanks for the pics
    1969 S Coupe #761
    Channel areas.
    The door sill is the easiest to slip in. The B-Pillar is not. You really need the tools. No screwdrivers! Once you have it close you can lubricate the blade, insert it behind the rubber and make a "pull" downward which will
    settle the piece where it needs to be for best contact with the U shaped seal.
    Start at the top of the B-Pillar corner where you've made your 45º cut (and glued seam). Once this is in, work down the B-Pillar are in front of the rear window. This will establish a good foothold and allow you to work without the thing
    dropping out. I still recommend doing short sections at a time. The glue gives you plenty of time to work the seal into place. There is NO RUSH. Relax and take your time. It took me 2 days!!! Not because it was difficult but because
    there isn't any reason to rip and run. This is a great job for the ADD folk who lose interest and have to find something else to entertain them in between rounds!
    Tom
    rgruppe #111
    Senior Member bobm's Avatar
    Aug 2011
    Northern California
    I am about ready to do this on a 66 Coupe. Where (which corner) should the 45 cut end up
    The cut is in the corner of the top rear of the door seen in the photo. The sequence in the photo is how I did it but there is no rhyme or reason other than I found it better to have worked the over-head section as I was going to the front so I could keep an eye on it.
    I've also marked the areas where the seal may put up a fight. (In the end they always give up!)
    Section 1 is without a doubt as hard as it gets. Especially the corner where the 45º's are cut. You really need the trim/door tools to get that in properly. NO SCREWDRIVERS unless they are made out of butter.
    Tom
    rgruppe #111
    Jan 2006
    Naperville, IL
    Very Nice Tom; Can I ask who's repro seal you went with?
    -Andrew
    '72 911E
    '82 931, '92 968, '93 968
    S Reg #1074
  1. Door/Window seals?
    By A.T. in forum Technical Info
    Last Post: 02-28-2014, 12:49 PM
  2. Door Seals New
    Last Post: 08-31-2010, 01:31 PM
  3. WANTED: door handle seals for 1969 door handles
    By obrut in forum For Sale: 911 Parts
    Last Post: 05-15-2010, 06:15 PM
  4. Replacing Door seals
    By Type911 in forum Technical Info
    Last Post: 11-06-2005, 01:57 AM
  5. door seals for SWB
    By mjmoran in forum Technical Info
    Last Post: 04-21-2005, 09:15 PM
