Page 8 of 10 FirstFirst ... 678910 LastLast
Results 71 to 80 of 98
Thread: 28 years with 9113601282
  1. #71
    Sep 2006
    San Francisco
    I've been looking for the correct side bracket to mount the short trumpet horn for about 5 years. Recently I found that S Registry member Clyde Bowyer was having brackets manufactured to the factory specs. Thank you Clyde! They are perfect!
    I finally got around to installing them, and this turned into one of those classic "as long as I'm in there" projects. Not that I'm complaining- these are for me some of my most rewarding times with the car. I always learn something new and I never fail to find some other things that should be fixed or refreshed.
    So I ended up pulling off both fenders, redoing the paint in the wheel wells, and freshening the trombone cooler and lines.
    I've seen and heard of a number of different horn configurations, but I've decided that this one is "correct". At least for me!
    Name:  2012-06-03 22.05.33.jpg
    Name:  2012-06-03 22.04.39.jpg
    Name:  2012-06-03 22.03.05.jpg
    Jeff Jensen
  2. #72
    Sep 2006
    San Francisco
    Thanksgiving was absolutely beautiful in San Francisco this year. And the city seems to empty out, making it a great time to take the car out and snap some photos with the Golden Gate Bridge as background.
    Name:  2012-11-22 12.29.43.jpg
    Attachment 232850
    Name:  2012-11-22 13.10.21.jpg
    Jeff Jensen
  3. #73
    Apr 2011
    N.Calif., south of SF
    Jeff- the car looks great!
    How did the fender removal go? The frontal area looks tremendous. Oh no another project suggestion!
    Haasman
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
  4. #74
    Sep 2006
    San Francisco
    Hi Jeff, the fender removal was surprisingly easy. I recommend having two pairs of hands when you lift the fender away, or at least put a blanket over the door if you do it yourself. The driver's side is a little fiddly with the tube guide for the gas flap cable, and I dinged the door a bit as I was pulling that fender off. Other than that it was pretty straightforward. Reinstallation was easy although the alignment and gaps aren't perfect; that will take some iterations to get right. I'm planning a full repaint at some point so I'm not too worried about getting it perfect right now.
    Jeff Jensen
  5. #75
    Apr 2011
    That's good to hear.
    Curious, did you torque the fender nuts? years ago I leaned of this and remarkably made a difference in the feeling of the front-end.
    Haasman
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
  6. #76
    Sep 2006
    San Francisco
    Did not. I knew there was an order to follow for reinstallation (which I admit I did not do), but I didn't know about the torque spec. Is the torque the same for all of them or does it vary by location?
    Jeff Jensen
  7. #77
    Apr 2011
    Jeff, They are all torqued the same value. I saw the infamous chart posted here describing the torque sequence a few months ago. I thought I had carefully saved it. I don't know the torque value. Again, the difference in my 65 was noticeable.
    Haasman
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
  8. #78
    Jun 2003
    Bend, Oregon
    Great thread. Reminds me that I'm still at enthusiast level 101 with a vertical learning curve.
    JohnA
  9. #79
    Senior Member mrgreenjeans's Avatar
    Nord Stern Region of PCA....west coast side of Region
    As well as most of us are, for the learning doesn't stop till the last breath is drawn
    Jeff this has been a tremendous read, thanks for all the great stories and pictures
    Best Regards,
    mrgreenjeans
    member # 1503
    -'68 -912 Red
    -'74 -914-2.0 litre - Sunflower
    -'82/83 -944 -M404 - Guards Red
    -'84 -944 -M456 - Guards Red -Weissach Prep. -H52
    -'84 -944 -M456 - Zermatt Silver
    -'84 -944 -M404 - Sunroof Delete - Ruby Red
    -'85.2 - 944 -M456 -Zermatt / Sport Purposes
    -'86 -944 -R74 Spt.Touring Pkg - White/Burgandy
    -'88 -944 - Jubilee Ltd. Ed. -Satin Black Met/Grey Plaid
    -'88 -911 - Tourist Delivery -Venetian Blue
    -'89 -944 Turbo M030 - Satin Black Met.
  10. #80
    Apr 2011
    Jeff- Here is the thread I spoke about with the fender torque sequence.
    http://www.early911sregistry.org/for...r-installation
    and here is the sequence-
    Name:  911 Front fender bolt torque sequence .jpg
    It is a bit hard to see the numbers, sorry about that. Maybe another member and provider a better copy
    Haasman
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
  1. New Years Day
    By raspy2point2 in forum Drives, Tours, Gatherings, Racing and Adventures
    Last Post: 12-31-2012, 04:03 PM
  2. New Years Eve and New Years Day Event
    By Eade Hopkinson in forum Drives, Tours, Gatherings, Racing and Adventures
    Last Post: 12-30-2005, 04:37 PM
  3. New Years Eve / New Years Day Info. For So.cal
    By swbsam in forum Drives, Tours, Gatherings, Racing and Adventures
    Last Post: 12-30-2004, 09:52 PM
  4. okay, who's doing what for new years ?
    By swbsam in forum General Info
    Last Post: 12-13-2004, 06:48 PM
  5. New Years Day Run(s)
    By RC70SCoupe in forum General Info
    Last Post: 01-02-2004, 03:08 AM
