Results 1 to 10 of 16
Thread: Turn signal problem '69 911T
    Recently replaced the turn signal harness. Turn signals worked for a while, then quit. I might have a short which would be a bummer tracing it to the problem. Any suggestions? Fuses are fine. Does this car have any other electrical component that regulates power to the signals? Thanks everyone!
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    Flasher relay behind the clock
    Junior Member
    Nov 2011
    Fort Worth, TX
    They quit all together? I would recheck the connections made during new harness installation. Also, make sure you are getting a good ground.
    [U]Wes Hall
    1970 911T Targa
    2003 Jeep Rubicon
    2001 Suzuki GSXR 1000
    Kubota RTV500
    Oh, I'm hoping that is what it is...do I get to from under dash or in trunk behind vent duct? Thank you!
    Nov 2004
    Gold Coast.
    You can access the flasher relay from the front trunk, you may have to disconnect the heater duct hose.
    Did that, all I see is the windshield wiper motor and the typical wiring to the dash. I would think I'd be seeing the square or round relay. I took out the speaker as well and can clearly see the back sie of the clock...
    It should be behind the combo gauge. If it were 70 and up you could just pull out the combo gauge, since it's a 69 you'll have to access it from the trunk side.
    Thank you! I found three stuck behind some vessel. What one governs the turn signals? One is square or rectangular, two are round.
    It is the rectangular one.
    Thank you very much!! For sure sounds broken, sounds like beads in a steel box! Pelican no longer stocks. The part # is 901 618 303 02. Made by SK66 12 v. 1-4 x 21W.
    Any other vendor you know of?
  1. WTB: US Front Left Turn Signal Lens to fit 1973.5 911T
    By Sessions in forum For Sale: 911 Parts
    Last Post: 03-11-2014, 08:19 AM
  2. Turn Signal Problem
    By jkolesa in forum Technical Info
    Last Post: 05-07-2010, 03:28 AM
  3. Turn Signal/Headlight Dimmer Lever problem
    By Torque in forum Technical Info
    Last Post: 06-28-2007, 07:16 AM
  4. Help with turn signal problem
    By Alan B in forum Technical Info
    Last Post: 11-01-2006, 02:31 PM
  5. WTB: '69 911T turn signal switch
    By eldon in forum For Sale: 911 Parts
    Last Post: 06-02-2006, 11:03 AM
