Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: FS 2.8L engine build parts...ready for assembly
    Dec 2004
    SE Michigan
    Selling all my 2.8L engine parts. Everything prep'd and literally ready for assembly. Rather than let this stuff sit around waiting for more time after my four boys have entered college, I want to see if there's any interest.
    The engine was to be a 10.3:1 2.8L twin plugged MFI engine. I'll list everything here, starting with the following. Prices w/o shipping (to ConUS only), paypal extra.
    10.3:1 92mm Mahle pistons/cylinders, brand new: $3900
    DC60 cams with MFI drive lug: **SOLD**
    twin plug distributer w/ trigger wire (SC core distributor): **SOLD**
    lower turbo valve covers w/ surface machined flat (powder coated): **SOLD**
    lower plug retainers: $55
    plug wire holders: $75
    two sets plug wires w/ coil wires: $350
    Will list more later, but you can ask in the meantime.
    Bill G.
    1968 911 Ossi Blue coupe...restoration complete!
    EarlyS #718 | RGruppe #437
    Jul 2008
    South Florida
    Bill, have you considered a price for the entire package?
    Russ
    ESR # 1537
    '62 356S Notchback Hotrod
    '67 S Das Geburtstagsgeschenk
    '68 T Targa Sportomatic
    '68 L SW Targa Sportomatic
    '70 914/6 GT
    Senior Member 911_2.2T's Avatar
    Jan 2007
    Netherlands
    I'll take the valve covers.
    E-mail sent on Dizzy and cams.
    2.4T 1972 Targa - Tangerine German Delivery Ölklappe
    2.4T 1973 Coupe - Golden Green 911ST with 2.8 MFI TwinPlug
    1.7 1970 914-4 - Hell Elfenbein Weiss to be Sonauto GT with a Six
    Looking for engine #6522576
    Rgruppe #674
    Dec 2004
    SE Michigan
    Quote Originally Posted by Bullethead View Post
    Yes, I have, but then people typically expect a discount. I think I can make out better by selling everything off individually. Whatever doesn't sell, I can keep for the next project. All the plated parts, gaskets and odds and ends can be used on my '68.
    911_2.2T, I will get back with you later today/tonight.
    Bill G.
    Isn't chemistry always nano?
    Aug 2006
    Are the P&Cs the 'old style' that give the huge compression when used with 2.4/.7 heads or the newer design to give 10.3:1 with 2.4 heads?
    t
    Nov 2002
    Fremont, CA
    Let me know on the dizzy and cams status if 911_2.2T passes. . .Thanks, kindersport@gmail.com
    scott kinder
    Registry #614
    Senior Member 2.5MFI's Avatar
    Sep 2006
    Bend, Oregon
    PM sent Bill.
    Mark Jung
    MFI Werks
    Early 911S Registry #972
    Carrera T w/LWB, MT, RWS, PCCB
    72 T 66 x 100 MFI Twin Plug Coupe
    R Gruppe #686
    Dec 2004
    SE Michigan
    Quote Originally Posted by 912-2.8 View Post
    t
    Not sure about your question. I am only aware of one offering by Mahle in 92mm 10.3:1 compression pistons for the "regular"/non-RSR head stud spacing. I have 2.4 heads that I had chamfered for the 92mm cylinders. I never got as far as setting the engine up and cc'ing the heads to figure out the actual compression. I do know compression always varies from the "official" number. You can see on the box that the manufacture date of the pistons is October 2003. I'd give someone like Henry at Supertec a call. Sorry, don't know if that helps.
    I believe when I bought these back in 2006 or so, they offered a 9.5:1 92mm piston. Those weren't available, and I seem to recall that I got the 2nd to last set of the 10.3 pistons in the US. They only do very small runs of these every 3-5 or so years IIRC. I still haven't seen a set of new 9.5 pistons, and who knows when, if ever, Mahle will do another run of these.
    Bill G.
    Quote Originally Posted by 911scfanatic View Post
    Interesting question IMHO. I believe the early 2.4/2.7 (911.83) cases used for the bigger bore 2.8s experienced cracked cases. And, then, there was a special case and P/Cs? for the later cases. However, I'm totally confused on this, frankly. Help? Thanks.
    -Allen-
    You'd think "DrRSR" would remember that, poser?!!!
    Dec 2004
    SE Michigan
    Quote Originally Posted by Dr 911E View Post
    -Allen-
    A 7R case, which became available around late-1972, will have no issues if the redline is around 7200. "Early" cases are non-7R cases. The spigots of a 2.7 case do not have to be enlarged to accommodate 2.8 cylinders.
    Bill G.
  1. 2.5 Race Engine ready for Willow Springs.
    By Minkoff in forum Technical Info
    Last Post: 03-28-2013, 12:18 AM
  2. WTB: Track-ready 2.0-3.0 engine or longblock
    By campbellcj in forum For Sale: 911 Parts
    Last Post: 07-06-2012, 11:56 AM
  3. For Sale: 2.7 RS Spec. Engine Ready to Build
    Last Post: 08-02-2010, 06:27 PM
  4. WTB: Parts for my 2.0 engine build
  5. Engine build
