Thread: engine popping
    engine popping
    I just purcased a 73.5 cis that had been sitting for a couple years. Drained gas, changed oil and new plugs. Started right up, has good oil presure and sounds great except for idle. It idles a little fast and pops. Will timing create this? What else could it possibly be? Thanks
    vacum leak or too lean
    May 2006
    CT
    A CIS car that has been sitting for a while will be subject to vacuum leaks due to old, cracked lines and seals. Be careful as this is the # 1 cause of the blown airbox.
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Why was it '. . . sitting for a couple years . . .'?
    Rick Kreiskott
    Paid Member # 1991
    Apr 2010
    Seattle, WA
    Quote Originally Posted by tom1394racing View Post
    +1 on this. Install a pop-off valve ASAP, if it doesn't already have one.
    - MR
  1. Stalling and popping
    By wsf80 in forum Technical Info
    Last Post: 04-17-2016, 11:27 PM
  2. Replies: 4
    Last Post: 12-04-2012, 05:32 AM
  3. Exhaust\Engine Popping
    By DarthMJH in forum Technical Info
    Last Post: 03-23-2012, 04:53 AM
  4. mech. inj. popping
    By 72starga in forum Technical Info
    Last Post: 06-19-2003, 12:38 PM
  5. Popping trunk lid
    By heirplane in forum Technical Info
    Last Post: 07-22-2001, 08:00 PM
