Page 11 of 12 FirstFirst ... 9101112 LastLast
Results 101 to 110 of 113
Thread: Normal Engine Temperature?
  1. #101
    Atlanta, GA
    I finally hooked up with the original owner, at least from 1975. According to him he had the motor rebuilt a couple of times during his ownership. The last time he had FBR do the work and he went with with "bigger jugs". Unfortunately, he the lost the receipt and all he could remember was that he thought they were the largest available at the time. He remembers getting a call from FBR asking if he "wanted more HP" since the P&C's were going to have to be replaced. He said "sure, why not". All he could remember was "2.83 or 2.7", but he said due to his age his mind was not as sharp as it once was. I have never heard of 2.83, but that is what he remembered. He said they went with the largest they could go with and stay with the std. crank. Any why to tell externally what I have? He estimated that the current rebuild would have about 30-35K miles based on his weekend driving. I will have to go through my records and look for clues. I will have to see if FBR could dig up a receipt from that far back.
    Mark Erbesfield
    1973 911S #9113301282
    1957 356A #58648
    1982 Toyota Land Cruiser FJ40
    1977 Toyota Land Cruiser FJ40
    1979 MB 450SL "Dad's old car"
    2019 Cayenne "Wife's car"
  2. #102
    even more reason to fit the cooler. Count the fins on your cylinders, there is a difference in the number between a 2.4 Biral and a 2.7 Nikasil although I can't remember what that number should be, 11 fins for a Nikasil? does that sound right?
  3. #103
    Mark,
    I've been going through both of your threads hoping to find some mileage and past mechanical history on you '73 with no luck......
    I was hoping by now an obvious problem and fix would have been found.....
    I've owned my '73S for 22 years here in sunny SoCal. The first two years without an external cooler, and the first 14 years with the stock 2.4S engine. The ONLY time I've experienced high temps, over 220, have been on the track in the summer.
    The 'normal' running temps should be between 180 and 210, as RPM goes up so will the temp but nominally. Other then summer, when I drive my car (even the first 2 years without the front cooler) at a constant normal RPM it hardly ever gets off 180.
    I even heard that back in the day that stock Early S's had the rep of being 'cold blooded little bastards'....
    I hope your temp issue is a combination of few little things that you are sneaking up on ....... however.... please remind us of how many actual miles this engine has on it.
    Has it been rebuilt?
    Most all these cars have had work done to them.
    When new these car's weak point was their top end.... Old mechanics said their top end were 'soft'. My records show my car's guides and valves were done at about 50,000 miles......
    I'm hoping not, but it might be your temp problem is a little 'deeper' then we've been thinking.
    Ed M., am I being way off base here???
    You're spot on Chuck! Tired engines run hotter
    However it appears the latest info may be that this is a 2.7 engine, bigger engine,,,,more heat!
  4. #104
    Atlanta, GA
    Yes, bigger engine according to PO. I have not counted the fins yet. Would a pic tell anything? i need to call FBR. Seems they would have noticed that when working on it and mentioned something to me, but maybe tv there is nothing notice. Or is it subtle? He did mention the fact that I have the good 7R case and the numbers match the COA. So that is goods new for starters.
    Mark Erbesfield
    1957 356A #58648
  5. #105
    It's surprising that FBR does not have a file on the work done to your car. My shop has a record of all the major work they've done on my car going back 25 years or so. I'm sure they don't have one for every car but just repeat customers and cars that they know are still going to be serviced by them.
  6. #106
    Apr 2011
    N.Calif., south of SF
    WAIT! I just read through 106 postings and .... Mark, what happened? Did you solve your overheating problem?
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
  7. #107
    Atlanta, GA
    I confirmed that my engine is in fact a 2.7. Been a while and I don't remember the number of fins on the cylinders, but it was the same no as whatever the 2.7 had, 15 comes to mind. As others mentioned, bigger engine needs extra cooler just been too busy to do it. I have all the parts needed, but between the 356A and the 66 911, my lift has been tied up. Car only gets hot in the summer, and I don't like to drive during the heat of the day anyhow without functioning a/c so has not been a problem.
    Mark Erbesfield
    1957 356A #58648
  8. #108
    Aug 2005
    VA
    Grady,
    where do you put the fan? The battery box is right hehind the cooler and the tire right in front.
    Chris
    73 911 E with Carerra fender cooler
  9. #109
    Senior Member smiles11's Avatar
    Oct 2021
    Northern California
    Reviving this thread. I recently took my 1971 911T that was completely rebuilt to 2.4L less than 3k miles ago. I took the car to Laguna Seca this past weekend and while I was caught in traffic on I-5 & once again climbing the Pacheco pass. The car was reaching temps around 235-240 degrees. Car has never done this before this past weekend. I understand the ambient temps have been higher, but I pulled over to let her cool down when I was stuck in construction traffic on I-5. The drive back from Laguna Seca, the car was settled between 190-210 most of the drive on a cooler morning. Is there something I should keep an eye on? I’m going to change the oil this weekend to be on the safe side.
  10. #110
    Apr 2011
    smiles11 - couple of questions-
    - what weight oil are you running?
    - does your car have an external oil cooler?
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
  1. Normal leak down numbers for 2.4S engine
    By shipard in forum Technical Info
    Last Post: 03-08-2014, 03:39 PM
  2. FS: 1967 911 normal engine- complete
    By TRE Cup in forum For Sale: 911 Parts
    Last Post: 02-23-2014, 10:57 PM
  3. Replies: 3
    Last Post: 11-06-2012, 03:34 AM
  4. 1961 356 Normal engine case/parts for sale
    By X-Faktory in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 01-04-2010, 05:17 AM
