Page 1 of 6 123 ... LastLast
Results 1 to 10 of 59
Thread: 911 engine case Revisions
    Oct 2008
    Burford, ON, Canada
    I've done a little bit of research on the casting part numbers found on the case halves of the 911 engine. As time went on the original number changed as the case design was modified. So, I want to try and document these changes. Naturally I will require help from you to try and determine all of the combinations and the range of build #'s or engine serial #'s to which the combination applies. The build #'s make it easy for most of the 2.0 engines since it has a linear progression with time. There are exceptions for the guidelines. For example I know of a few magnesium cases that preceded the introduction of the new design in volume production. Also, there were aluminum cases made for racing purposes that apparently use the same dies as the late magnesium case.
    901.101.101.01 901.101.102.01 AL 1 5071
    901.101.101.10 901.101.102.10 sandcast MG for 906 engines
    901.101.101.02 901.101.102.01 AL 5224 9272
    901.101.101.0R 901.101.102.0R AL 9730 12050
    901.101.101.1R 901.101.102.1R MG 12134 15415
    901.101.101.2R 901.101.102.1R MG 17421 1970
    901.101.101.3R 901.101.102.2R MG 1970
    901.101.101.3R 901.101.102.3R MG 1971
    901.101.101.4R 901.101.102.3R MG 1972
    901.101.101.5R 901.101.102.4R MG 1973
    901.101.101.5R 901.101.102.7R MG 1973
    901.101.101.7R 901.101.102.7R MG 1973 1977
    901.101.101.7R 901.101.102.7R AL 1973 RSR
    911.101.103.0R 911.101.104.0R AL 1973
    930.101.103.4R 930.101.104.4R AL 1978 1980
    930.101.103.6R 930.101.104.5R AL 1983
    Oct 2008
    Burford, ON, Canada
    Oct 2008
    Burford, ON, Canada
    A change to the left half of the case somewhere about build 5200; seems to be coincident with the new type 901/02 911S engine introduction.
    Perhaps a minor change occurs about build 9200 with the introduction of the 1968 model year production, and the chain housings change from 3 fasteners and 2 solid dowels to have 5 threaded fasteners.
    Oct 2008
    Burford, ON, Canada
    This is the third version of the aluminum 901 case, beginning about build 9730, perhaps earlier.
    This, the first of the "R" cases was short lived with about 2000 to 3000 produced.
    Doing a bit of research indicates that most people with this case find they are not numbered; replacement cases.
    Oct 2008
    Burford, ON, Canada
    The first Magnesium case from build #'s near 12100, although build 11474 is one of a few prototype engines built to test the new design before volume production.
    Oct 2008
    Burford, ON, Canada
    The left case half changed
    Oct 2008
    Burford, ON, Canada
    Both case halves changed, was this done in unison?
    Oct 2008
    Burford, ON, Canada
    The right case half changed this time. This was used in 1971.
    Oct 2008
    Burford, ON, Canada
    The left case half changed again. This was used in 1972.
    Oct 2008
    Burford, ON, Canada
    Both case halves changed.This was used in 1973.
  1. Replies: 2
    Last Post: 11-20-2008, 11:50 PM
  2. 962 engine case
    By EARLY911ZOO in forum For Sale: 911 Parts
    Last Post: 09-26-2008, 04:08 PM
  3. FS: Aluminum Engine Case - Type 901/01, Engine 902409
  4. WTB 7R engine case for 911
    By wolfturbo in forum For Sale: 911 Parts
    Last Post: 08-29-2005, 05:10 AM
  5. Bulletin Board revisions
    By 911SRegistry in forum Technical Info
    Last Post: 08-28-2001, 08:02 AM
