Results 11 to 20 of 50
Thread: SWB Relays Analyzed
Threaded View
    SWB Relays Analyzed
    It looks like there are SIX relays in an early 911
    These carry part numbers
    901 615 102 00, for horn, heating blower, ignition coil (quantity 4)
    PCG 615 101 10 for headlight flasher (quantity 1)
    PCG 615 101 10 for fog headlamp and warning light (quantity 2)
    That totals seven relays. . . (somebody needs to help the PET editors count. . . )
    Yellow Relay- Control Light Relay. This is a specialized relay with only terminals 30, 86 85, and 87a. Note that it is missing the normally open contact 87 that modern relays have. 30 is a black wire from fused side of Fuse #1, direct connection to battery. 86 is the hot side of the relay coil, this is wired in parallel with terminal 30 of the flasher can, when the coil is energized, the flasher is powered up and the relay contact opens, removing power from the normally closed terminal 87a. 87a, in normal operation carries power from 30 across the relay contact to the blink light unit. 85, of course, is the ground, in parallel with the S terminal on the flasher. Interestingly, this relay, and therefore the flasher coil, are switched by the ground side of the circuit- when you pull the hazard knob out, you are completing the path between 85 and ground.
    Gray Relay- Relay for Light Signal 30/56, 57, 85, 56b, 56a.
    57 on the light switch is the low beam contact- when the switch is pulled out current flows to the ignition switch. If the ignition switch is in the "run" position, then current flows to the stalk switch. With the stalk switch in the normal position, current flows to the unfused side of relays 9 and 10, which does three things- it illuminates the low beam bulbs, illuminates the warning lamp in the speedometer, and flows through terminal 57 of the relay through the coil to ground 85, energizing the coil and diverting current from 30/56 to the 56b (low beam) contact.
    Fog Light Relay -Photo Copyright Tom Bridgers- the fog lamp harness is described here
    [http://www.early911sregistry.org/for...g+wire+harness
    This must be for TTG fog lamps, because in the regular 911/911s diagram, the fog lamps did not use a power relay. Again, this is a yellow relay with only 30, 86, 85 and 87a. We know that when you flip on the high beams, the fogs go out, right? That makes sense-- this relay isn't switching the power for the fogs, it's switching them OFF when the high beams come on. That is the only explanation for using a yellow relay-- the power to the fogs is carried between 30 and 87a, and when the relay coil is energized from the high beams, the wiper breaks the circuit. If you look in the photo below it looks like the terminals of the yellow relay are: 85 (ground) at top right, 86 (coil hot) at bottom right, 30 in the middle and 87a at lower left. That means that when power from the fuse box is present on the big yellow wire, the relay opens. Looking at the diagram in the thread referenced, you can see that the wires make a triangle-- from fuse box #2 to switch contact #2, from switch contact #1 to terminal 87a, and from terminal 30 to fuse box #3. The lamps are wired in series, presumably from fused side of #3 to one lamp, to the other lamp and then back to fused side #2. I guess the ground is present at the switch to provide a ground path for illuminating the indicator.
    Horn Relay -The horn relay is down by the battery -See Photo below from Bob Tilton- and usually is pretty rusty. In the photo below, you can see the harness connections-- two black/yellow to the multiple 30/51 terminal, 87 is a red from the UNFUSED side of fuse Nr. 4 to the normally open contact and a multiple to the hot side of the relay coil 86, 85 is switched ground brown/white through the horn button. (Instead of a pure brown ground, it has a white tracer). The stamp for the horn relay is described here: http://www.early911sregistry.org/for...ghlight=wehrle
    Ballast Resistor Relay - - Photo Copyright Nate Y. System logic is in the diagram-- 30 is a red/white to the bus connector on the electrical console, 86 coil hot is a yellow to the starter, 85 is ground, 87 NO contact is a black wire that goes inside the ballast resistor case, then out to the coil. The photo below (with the black background) is the ballast resistor relay, it appears identical to the horn relay, even though one of the terminals is not used in this application.
    Webasto Heater Relay -A "conventional" relay with 85 ground, 86 switched power from ignition contact 75, 30 power from the battery positive through a 25A fuse, and 87 the normally OPEN contact connected to pole 1 of the Webasto switch. In this respect it is the same as the Ballast Relay and Horn Relay. All this does is enable the heater only when the ignition is on.
  1. FS: Early 911 Relays
    By Jim Williams in forum For Sale: 911 Parts
    Last Post: 11-17-2013, 07:15 AM
  2. SWB Relays
    By hoffman912 in forum For Sale: 911 Parts
    Last Post: 03-09-2012, 06:00 AM
  3. WTB - Standard 911 Relays...
    By beh911 in forum Technical Info
    Last Post: 10-27-2011, 08:30 AM
  4. FS-NOS relays
    Last Post: 02-27-2010, 03:57 PM
  5. Engine Bay Relays...what do they do?
    By tgittens in forum Technical Info
    Last Post: 01-07-2010, 06:43 AM
Tags for this Thread
