Results 1 to 10 of 11
Thread: Door check does not hold door. Suggestions?
Hybrid View
    I have a '73. The driver's door stop/check is not working. Once you open the door, it does not stay, it opens all the way.
    I heard that the door check sold by the regular vendors does not fix the problem. Is this correct? If so, what is/are my alternative(s)?
    I welcome any suggestions.
    Thanks a million,
    Jesse Rodriguez
    S Registry # 657
    R Gruppe # 70
    Depending on the year of you car, the new door checks do not fit at the mounting points in the door. Some have drilled out the inner door as to make a new hole for fitment purposes. I did not do that. Instead, I purchased some old door checks, took them a part and used parts from the several door checks to make one good one. New rollers are available with most vendors. Grease it up and you should be good to go. Good luck.
    RGruppe member 445
    Aug 2020
    Shawnee, OK
    Pelican has Porsche Door Stop - 90153103520 - Genuine Porsche
    which solved the problem its about $100 and I believe it has different threads than my 69 original, so you would have to use different bolts. Pelican probably would know if it would work on your 73. I tried to fix mine, but couldn't, as the plastic parts were too worn, so went the new route. You will have to take the door panel off.
    Good luck.
    I think this one was the original design,
    https://www.aasesales.com/collection...37-114c-114366
    Take a peek at what you've got
    Apr 2012
    Simi Valley Ca
    What a dilemma! $30, $100 or $200.
    Bob B
  1. Door Check not working
    By BlackC4 in forum General Info
    Last Post: 06-06-2013, 06:26 PM
  2. price check - nos rhs door
    By advtracing in forum General Info
    Last Post: 10-31-2011, 05:46 AM
  3. door check rebuild?
    By chiroracer in forum Technical Info
    Last Post: 03-30-2010, 02:51 PM
  4. FS: Door check rod
    Last Post: 10-25-2009, 08:40 AM
  5. Wtb 73 door stop/check
    By denson in forum For Sale: 911 Parts
    Last Post: 09-13-2009, 09:48 AM
