Page 2 of 9 FirstFirst 1234 ... LastLast
Results 11 to 20 of 84
Thread: Solex 40 PI carburetors - untangling a mystery
  1. #11
    Sep 2006
    La Quinta
    "Knock on wood"...I've never had a problem with the solex carbs.
    1962 356 Cab, show car, sold.
    Registry #983
    R Gruppe #741
  2. #12
    Nov 2003
    Sydney
    Kenik,
    Even though I probably won't own a Solex carb 911,I find threads on these 'dry sump' carbs fascinating because the whole fuel/carb system in an early 911 is an elegant engineering sub-system in its own right !
    Similar to the front hydro struts introduced in 1969 MY,the Solex carbs are another 911 feature that weren't quite tested and production ready at the release date of the 911 in 1964.Maybe Piech had the engineers hot on the trail of a future 917 instead !!
    This is confirmed by the subsequent correction/s data from the factory mod and the emulsion tube data.
    Other problem areas should be due mainly to wear and tear over the years eg shaft bushings and soggy floats.
    The Solexes were designed specifically for the 911 and the Webers came from a Lancia V6 IIRC which explains the barrel spacing differences.
    I stopped by to talk with Mark(?) at Laguna Seca last August and he seemed happy with the performance of his Solexes and the twin pump system !
    Obviously an hour at the track is different to 40k street and highway miles but he is still using these carbs.
    IMHO development of the Solex carbs should have continued until production ready(off the soap box now !).
    Maybe David - LKG 6D - might want to join in here.
    Keep up the good work and MORE Solex porn pls !!
    Cheers,
    Dennis.
    S Registry member 536
  3. #13
    Quote Originally Posted by kenikh View Post
    NOS rebuild kit:
    I'm not totally sure what this is - looks fuel related:
    Did someone mention my name
    That part is 901.108.029.00 - Oil Outlet Tube. I need one of those if it's spare Kenik?
    If you're using the mechanical pumps as I do, replace the fibre washer with one of these, the original always leaks. I have some spares if you need one, come to think of it I'm sure I owe John Cramer a pair?
  4. #14
    Aug 2007
    Phila Pa. area
    carb
    I thought the Solex factory had a fire, and Porsche had to go to Webbers?
    Mike
  5. #15
    oil outlet tube
    [/QUOTE]
    I see that others have already replied, but for further clarification...regarding the oil outlet tube. I did the same thing with my tub of 71E parts...held that in my hands and went WTF is that?
    Regards,
    al
    Al Kosmal
    the X-faktory
    Current projects; 69-911.5
    76S rat bastard---off to Germany
    1970 914-4...off to Wisconsin
    73 911X Cafe Racer...........(off to S.F.....now racing in Germany)
    66 912 ...off to France
    71E 9111200979 ( gone to Paris..then to Corsica)
    77S (off to NY)
    Early S #1240
    RGruppe #669
    www.x-faktory.com
  6. #16
    Sep 2006
    La Quinta
    It has a little rubber part that goes on the bottom. Part # 12 on the drawing.
    Registry #983
    R Gruppe #741
  7. #17
    Quote Originally Posted by LGK6D View Post
    Sure, would love to have them - what kind of washer are they? Mine are fiber as you can see.
    No extra oil tube, unfortunately or you could have it.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
  8. #18
    Kenik, PM me you're address and I'll send you two. Might be a little slow with the postage though as we don't have any inbound or outbound flight due to the volcano in Iceland
  9. #19
    The Brown Fairy paid me a visit today - this what what good little boys get for no particular reason other than they WANT it...
    Details, details...
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
  10. #20
    Are the plastic fittings normal?
    More, more, MORE!!!
    Mmmmmm...minutia:
    Every throat has one of the perfect little part number tags on it...sweet, huh?
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
  1. FS: Excellent Set of Solex Carburetors
    By dporsche74 in forum For Sale: 911 Parts
    Last Post: 10-31-2013, 07:06 AM
  2. FS: Solex PI carburetors for 65-66 911 cars
    By VintageExcellen in forum For Sale: 911 Parts
    Last Post: 08-16-2013, 07:59 AM
  3. FS: Solex Split Shaft Carburetors
    By jaudette3 in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 06-11-2013, 10:03 AM
  4. Who to rebuild Solex carburetors?
    By YTNUKLR in forum Technical Info
    Last Post: 11-27-2006, 06:56 AM
