Results 1 to 10 of 13
Thread: Is the Bosch RPM transducer still available?
    Pay to play Schiefer's Avatar
    Jun 2008
    Norway
    Hi.
    My "Zeitschalter" is totally fried, and I need a new one.
    Are they still produced, or is a used one my only option?? I called Porsche Norway but they could not find it.
    Info from Zithlord probably from this forum:
    PN 2k 9711 0336611006 "RPM transducer" AKA "speed switch"
    The RPM Transducer receives 12V (ignition-switched) power. When the distributor/tachometer wire signal says the engine is above 1500 RPM or so, it sends power to the microswitch. When the throttle arm contacts (closes) the microswitch when you are off the accelerator pedal, the fuel shutoff solenoid is activated. This pushes the injection pump main rack past full lean and shuts off fuel flow. The engine then slows in RPM. At the point that the distributor says the engine is below 1500 RPM, it opens the circuit to the microswitch and the solenoid retracts, allowing idle fuel flow to keep the engine from stalling.
    S-Reg #1382
    67S Lavender
    der Zeitschalter = "Time Switch" auf Deutsch-- what you show in the photo is NOT the MFI rpm transducer but a different relay.
    http://forums.pelicanparts.com/showt...+switch+number
    The transducers are NLA- but can be rebuilt, either professionally (Otto's Venice) or by skilled amateurs.
    http://forums.pelicanparts.com/showt...i+speed+switch
    So is the relay shown the one for a two stage defroster? I see now that is dos not have the correct Bosch number for the RPM transducer "speed switch" as stated above.
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
    Jun 2008
    Norway
    Confused
    Hmm. Confused again
    Must read and think and talk with John and my mechanic.
    This is what it looks like inside.
    S-Reg #1382
    67S Lavender
    if your rpm transducer is bad, a lot of people just disconnect the microswitch. you'll probably get some backfires on occasion when lifting off.
    Quote Originally Posted by Zithlord View Post
    I would say "No" because those relays are all Hella built. The link that John posted had pictures of 2 other units which look similar in construction, but not the same. Edit: I will also add that the one in my car has an old Bosch sticker and logo. This does look to be a newer part as Zithlord mentions below.
    Olin - Member #1375
    1972 911T
    Original
    Options added
    I have read some treads written by among other Warren Hall. This relay pictured is indeed a RPM tranducer/speed switch, but might be a later replacement part, made in Malaysia and not West germany. Read these treads that confirm that 0.333.400.100 is a RPM tranducer/speed switch. It can be found several places on the web stores but price is in the 150 euro area.......
    http://forums.pelicanparts.com/searc...archid=3873487
    You guys are right, I am wrong. I found it in Bosch under the Porsche number.
    It supercedes 0 336 611 001.
    Looks like still available at $382. http://www.pelicanparts.com/cgi-bin/...DINJ%2E%20PUMP
    Jun 2008
    Norway
    Thank´s.
    I have learnt a lot today about this strange little box. Now I even know where to buy it
    S-Reg #1382
    67S Lavender
    Norway's a long way from NYC, but I'll bet John would buy you a beer at McSorley's if you're ever in town.
    I have a website now:
    www.markmorrissey.org
    Instagram: @Mark0Morrissey
  1. WTB: RPM transducer
    By 50/50 in forum For Sale: 911 Parts
    Last Post: 10-01-2013, 02:48 PM
  2. WTB: RPM transducer
    By Flieger in forum For Sale: 911 Parts
    Last Post: 05-29-2008, 08:26 PM
  3. WTB: working RPM Transducer for a 70 S
    By mhackney in forum For Sale: 911 Parts
    Last Post: 07-12-2007, 05:40 PM
  4. WTB: MFI transducer
    By dhopkins in forum For Sale: 911 Parts
    Last Post: 10-03-2005, 06:50 AM
  5. WTB:working MFI transducer
    Last Post: 08-18-2005, 07:11 AM
