Results 1 to 5 of 5
Thread: Need help with advanced search
    I would like your suggestions. When I am looking up a topic,for example, where to find stamped numbers on steel wheels, I go to "Advance Search" and type in "wheel number location". It doesn't focus enough on my topic. Is there a better way? Thanks.
    This thread might help:
    https://www.early911sregistry.org/fo...3-Steel-Wheels
    When a site search doesn't to it, I use a Google Search attached to us:
    https://cse.google.com/cse?cx=016979...39:72_tapbymt8
    Hope this helps,
    Chuck
    Member ProfHollan's Avatar
    Aug 2016
    La Jolla, CA and Albuquerque, NM
    I always use google search rather than advanced search. You can limit the search to a site. For example one might do a search like:
    site:early911sregistry.org ed mayo
    I often do that with another keyword to look for one of Ed’s answers to a question.
    1973 911E Targa
    Firemist Cognac
    Searching the Registry . . .
    . . . a better way
    https://www.early911sregistry.org/fo...egistry-forums
    HtH
    Thank you for the help!
Tags for this Thread
