Results 21 to 30 of 40
Thread: '65/'66 ignition switch refit hell - experts needed
  1. #21
    The power to the ign. switch actually goes to the light switch first from fuse # 2, then from the light switch (red/white? diagram shows red) to term 30 (30 is always a 'hot' term.) of the ign. switch. Then from term. 15 (15 is always 'ign.on') of the ign. switch to fuse #1 from there power is sent to the instrument panel and to the ignition coil. Term. 50 (is the starter power) gets the big yellow wire that goes back to the starter. Term 75 is the radio power so it works on both access. and ign. on.The grey wire term. 57a should go to the turn signal switch term. 57a. The small yellow wire doesn't show on the diagram, later addition? On later cars that was the radio power wire. Do you have a newer radio that requires memory? Have I got you confused now?
  2. #22
    bullet connectors
    I have never seen bullet connectors on a 911 -912.
  3. #23
    Feb 2005
    Lake Tapps, WA
    Hey Kenik, this is what I have from my notes...
    30 - Red to turn signal switch
    30 - Red to headlight switch
    15 - Red to grey connector, then to #1 fuse
    50 - Yellow to grey connector, then to starter
    54 - Rd/Wt to connector, then to radio?
    57 (Pa) - Grey to turn signal switch
    My car is not here though but should be on Thursday so if you want some pics, let me know
    '67 911S
    '69 911S
    '70 911ST
    '73 911T Targa Signal Yellow
    '11 Spyder
    Early S#1097, R-gruppe #
  4. #24
    Jan 2007
    Phoenix, AZ
    There is a tag that goes in the middle of the switch to id the terminals. Mine fell off after that photo(several years old) but I found it in the glove box this morning and updated the drawing. Should be the missing link to the wiring diagram!
  5. #25
    -EDIT- You guys are fast - answering my questions while I am still typing them!!! Thank you!
    There used to be an '80s Becker in the car. This now makes sense.
    Here's how I am mapping this:
    A - PA (57 per Chris) - turn signal switch
    B - 30 - 'hot' term
    C - Empty
    D - 30 - 'hot' term
    E - Empty
    F - Empty
    G - 15 - 'ign.on'
    H - 54 - radio power?
    I - 54 - radio power?
    J - Empty
    K - 50 - starter power
    Which one is term 75? Same as 54?
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
  6. #26
    Feb 2005
    Lake Tapps, WA
    Pa is 57 on my switch
    '67 911S
    '69 911S
    '70 911ST
    '11 Spyder
  7. #27
    Quote Originally Posted by endo911rs View Post
    I edited my post above - thanks!
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
  8. #28
    I got sidetracked installing 67mm wheel studs, 21mm spacers and my sport muffler, so just got back to this today. For anyone curious, the "through the e-brake cable hole" method works like a charm.
    The car now starts, but no headlights or blinkers, so I know which wire goes where. Sometime this weekend I will have the car back together and my old Becker Europa will be powered off of the ignition and a little amplifier installed to boost it over the road noise. Treffen prep is coming along nicely!
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
  9. #29
    OK, problem.
    The white wire with black stripes is giving me fits. This wire, when powered, turns on the lights without involvement of the headlight switch. When hot, the lights go on. Hi/low switch works fine. This wire leads to the turn signal stalk. If I put this wire in 54, I get daytime running lights, but I prefer not to go this route.
    I assume that this wire needs to get its power from the headlight switch, not the ignition. The wires I can see coming from the switch are thick red, thin red, yellow. All seem involved with ignition. Which wire is the power to the light switch and which wire brings switched power back to my white wire/black stripes?
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
  10. #30
    Kenik, the white w black wire from the column switch should go to term 56 of the light switch. Try that.
  1. Replies: 0
    Last Post: 08-13-2011, 01:19 PM
  2. E Bay experts search help needed
    By BOYER73S in forum Technical Info
    Last Post: 07-02-2011, 05:53 PM
  3. Needed...ignition switch for my R clone
    By speedo in forum For Sale: 911 Parts
    Last Post: 05-11-2009, 09:29 AM
  4. Antenna experts needed
    By John Fusco in forum Technical Info
    Last Post: 10-22-2007, 09:19 AM
