Page 42 of 144 FirstFirst ... 3240414243445292142 ... LastLast
Results 411 to 420 of 1437
  1. #411
    Oct 2008
    Burford, ON, Canada
    Thanks Robin. Since this engine is apart, can you provide the casting dates for each half for the pulley end of the case, and the pairing number from the top of the case, please. Can you also confirm the casting part #'s on the case sides end with 1.02 & 2.01
    I spoke with a fellow the other night that has engine 900393. It might be available to reunite with the original car if it can be found; VIN unknown at the moment.
  2. #412
    HI Engine it built at the moment, i have another 65 engine that's dismanlted, i'll get that info for you when i see my engine builder soon. The 66 engine hs no time ware/fan/alt at the moment so I can get most of the numbers for you.
    The 900393 engine, do you know what VIN? I have a frind with VIN 300147 - http://r-to-rsr.com/1964-porsche-901...-r-to-rsr-ltd/. ny estimate of VIN?
  3. #413
    pairing number 837
  4. #414
    HI Dve
    Got another engine - dismantled but details for you below
    901/03
    serial number 12505
    pairing number 081
  5. #415
    Oct 2008
    Burford, ON, Canada
    Robin, what is the serial # for 12505?
  6. #416
    sorry it's 2080699
  7. #417
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    Didn't see this one posted yet.
    119300024 has:
    901/10
    6390033
    16268
    http://www.early911sregistry.org/for...le!!!%29/page2
    1969 S Coupe #761
    Early S Registry #1624
  8. #418
    Oct 2008
    Burford, ON, Canada
    Thanks, one has to spend time cruising the old posts to find these bits of gold. I'll have to update the list very soon.
  9. #419
    Here's some new information for you, Dave.
    901/01 ... 903356 ... 3256 ... 790/790 (pairing number)
    Here's some interesting info on the casting dates...
    The 1/2/3 case half is dated 3/65 (three dots)
    The 4/5/6 case half is dated 6/65 (six dots)
    -Marco
    TLG Auto: Website
  10. #420
    Oct 2008
    Burford, ON, Canada
    Those casting dates are very strange. Partly because of the difference in dates, but also because they are far earlier than might be expected. About 800 engines later than I might have expected. Could you document this engine with photos of all the numbers and so on please.
  1. Martini RSR engine build
  5. Engine build
