Page 12 of 144 FirstFirst ... 210111213142262112 ... LastLast
Results 111 to 120 of 1437
  1. #111
    Oct 2008
    Burford, ON, Canada
    Thanks for the new info guys. I'll update the first post tomorrow. Yes, that is the earliest Mg case in my database. That really narrows the gap down to about 60 build #'s.
  2. #112
    Oct 2008
    Burford, ON, Canada
    Here is an interesting engine case for sale: 901/16 6197299
    So why is it interesting? The factory literature says the last one built is 6197292
    So it is very late, and if I can get the build # it should be interesting.
  3. #113
    Is it me or are the first 5 numbers dark while the last two are shiny? Would it make sense that the factory might set aside some cases for stamping at a later date?
    Peter Kane
    '72 911S Targa
  4. #114
    Oct 2008
    Burford, ON, Canada
    The case was painted red, and the lighting is poor although the use of a flash is evident. The original resolution was poor also, so I had to massage the image a lot to try and make it readable. I think Porsche record keeping was poor; I find evidence of that regularly.
    New info from George:
    NO BUILD # obviously it was discontinued before the end of model year production!
    4 digit case pairing number 0214, had only seen 3 digits before
    3R case
  5. #115
    911R Numbers
    Of the three R engines I have Numbers for, only one has an original case. 901/22 - 11089 - 5080012. The others had replacement race cases but Numbers were questionable. gordon
  6. #116
    Hi dave got your PM.
    I'm guessing my 66S may be the oldest surviving in the world?
    It was an August 5th build date 1966.
    Chassis 305360
    Engine 960073
    Transmission 103077
    Type 901/02
    It will be up for sale in a few weeks time as it has just finished extensive restoration and thinks I have bottomless pockets! It was certainly worth doing for such a collectors piece but unfortunately circumstances and way too many cars/toys means she will have to move on
    Hope this helps and great work on the database
  7. #117
    Quote Originally Posted by 964RS UK View Post
    Chassis 305360
    Engine 960073
    Transmission 103077
    Type 901/02
    305279S, not mine, is in So. Cal. or was a little while back.
    -Allen-
  8. #118
    Oct 2008
    Burford, ON, Canada
    Chassis 305360
    Here is an old thread on the topic:
    http://www.early911sregistry.org/for...ead.php?t=8524
    305133S still seems to be the earliest, and Max is still active on the forum.
  9. #119
    Guess its debateable if any were built BEFORE August 5th....but lets just say oldest outside US for now then
  10. #120
    Oct 2008
    Burford, ON, Canada
    See this post for some interesting info on the production dates for the 1967 models.
    http://www.early911sregistry.org/for...34&postcount=7
    They started very early in 1966 building the 1967 models.
  1. Martini RSR engine build
  5. Engine build
