Page 47 of 144 FirstFirst ... 3745464748495797 ... LastLast
Results 461 to 470 of 1437
  1. #461
    960885 is a 911S engine type 901/02 (not sure why you have 020, but figure it is a typo), and well into the production of that type. Still an aluminum case, probably cast Aug 1966, with case half versions 1.02 2.01. The left case half is the second version that was introduced at the time of the 911S engine, so I believe it has something to do with the needs of the S engine. It would be interesting to know the casting dates on each half, and the pairing #. Original engine to car with VIN near 306900 built in mid Dec 1966.
  2. #462
    Yes, the 020 was a typo. I thought it was an S case but wasn't 100% sure. I'll get the rest of the info when I can.
    Thanks.
    -Marco
    TLG Auto: Website
  3. #463
    Aug 2013
    Hi,
    I have engine # 2081351 with case number 14806 and a 901-03. Please advise if this is aluminum or Mag??? thank you and your thread is FANTASTIC.......
  4. #464
    case number 14806 indicates a mag case; (anything over 12100 is mag, the transition is somewhere between 12000 and 12100). Thanks for the info.
  5. #465
    Porsche Certifikat on my Porsche 911 1967 with matching numbers.
    Former owned
  6. #466
    Port Macquarie, Australia
    I'll play... My 68s are:
    901/14 3281365 15412
    901/02 4081144 14179
    John Forcier
    EarlyS #1987
    Restoration Saga
  7. #467
    Junior Member pdanguin's Avatar
    Feb 2011
    PARIS
    my car:
    Name:  PORSCHE 2.0 65 BELGE 011.jpg
    type 901/01
    serial 901554
    build 05/13/1965
    Compulsive Collector
    2.0 65
    2.0S 68
    2.4TS sporto 72
    2.4S 72 Grp4 2.5ST
    2.4S 73
    3.0SC safari (project)
  8. #468
    Another for your research................
    My 65 has eng. 901197, Type 901/01, build no. 1097.
    Any ideas on when it was produced ?
    Thanks in advance.
  9. #469
    Thanks. 901197 was in a car completed about May 1965. The engine itself was probably produced in March or April. We could narrow things down a bit if you can find the date codes on each engine case half that would be found behind the crank pulley. Look for a two digit year (65) surrounded by a ring of dots (count the dots).
  10. #470
    Oct 2013
    type 901/14
    serial 3280072
    build 9730
    pair 456
    casting date 6/67
    Where does one find the data to know what VIN this engine belongs to?
  1. Martini RSR engine build
  5. Engine build
