Results 1 to 10 of 24
Thread: pedal board restoration
Hybrid View
    another little project or "how i spent my winter vacation"
    most pedal boards can be repaired.
    below 2 pictures of my drivers side board.
    note the extensive rust on mounting plate, delaminations, wood defects, water stains and oxidized hardware.
    not pretty
    bob moglia
    '72 E sunroof coupe
    step 1
    disassemble as necessary
    repair delaminations:
    separate layers with toothpicks and brush layers with yellow wood glue.
    cover with wax paper and clamp securely for 24 hours.
    if there are buckled areas, split them open with a razor blade and elevate edges.
    apply glue and again clamp overnight.
    bob moglia
    '72 E sunroof coupe
    step 2
    repair wood defects.
    if missing pieces, fashion from a donor plywood source.
    1/4" birch plywood works great. you can get this at a hobby shop.
    or you can purchase wood veneers at woodcraft.com
    split off the layers with a sharp knife. trim fit and glue.
    you could also use wood putty.
    when dry, sand thoroughly.
    stain with minwax EBONY.
    coat with satin polyurethane to waterproof.
    pic 2 shows several small repairs note the light areas.
    also what a difference sanding makes.
    bob moglia
    '72 E sunroof coupe
    final result
    clean all hardware and install.
    i think it was worth the effort.
    i'm still working on replacing that mounting bracket.
    i'm looking for the right rivets; part of my OCD
    bob moglia
    '72 E sunroof coupe
    Rennline
    I know you are looking for originality, but has anyone tried aluminum floor boards from Rennline and can comment on their quality?
    S Registry #1280
    1970 911T
    1968 911 FWT
    1965 356 SC
    Quote Originally Posted by Max (SD)
    I hate them. I think they're absolutely ghastly and they don't have the proper provision for the pedal stop needed on the pre-76 911s with the rubber gas pedal. Ugh.
    -Marco
    TLG Auto: Website
    The easy way
    Or take the easy way out and call Stoddard!
  1. FS: Driver Side Pedal Board LWB Coupe
    Last Post: 05-12-2012, 08:35 AM
  2. WTB: OE pedal board and floor board for 65-68 cpe
    Last Post: 04-06-2012, 07:53 PM
  3. FS Pedal board for 68 Sportomatic
    By Terry Forland in forum For Sale: 911 Parts
    Last Post: 11-25-2011, 11:23 AM
  4. WTB: Pedal Board for '68 SWT
    By jaudette3 in forum For Sale: 911 Parts
    Last Post: 10-09-2009, 09:23 PM
  5. Sportomatic Targa Pedal Board
    By JT912 in forum Technical Info
    Last Post: 07-27-2009, 04:13 AM
