Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: MFI oil supply?
  1. #11
    mechanical injection parts
    John and Neil,
    I saw the oil pressure sender on eBay, Item number: 230230901326. The listing contains two senders. The one on the left includes the banjo bolt for mechanical injection. You can see the same in my photo in this post.
    I bought my oil feed line from PAP-parts.com for $30. You'll also need the two aluminum washers for the banjo connection. The return hose is just a piece of 10mm or 3/8" hose.
    If I can hijack this thread - If anyone has any, I am looking for the sheet metal cover over the injection belt and also the duct that goes over the oil cooler.
    Can anyone tell me where the hose goes to from the thermostat that is on the top of the injection pump? I know that air from the fan blows into it and the pump compensates for air temperature, but I don't know how it gets the air. Maybe from the heat exchanger flapper somewhere?
    Bob
  2. #12
    MFI oil pressure sender
    Here's a better picture of the oil pressure sender.
    Bob
  3. #13
    thermostat
    The air to the thermostat comes from the small tube that is part of the driver side exhaust system. The driver side sheet metal piece that runs along the side of the engine on MFI cars has a tube welded through it, a hose goes from the heater box to the tube, and then another hose goes from the tube on the enginr side to the thermostat. I may have the sheetmetal.
  4. #14
    Thanks. I'm pretty sure I now understand how the air gets to the injection pump thermostat. I've seen the tube in the heat exchanger, so that now makes sense. Does the outlet of the thermostat also have a hose going somewhere?
    I would be interested in the sheet metal. If you find that you have, please let me know what you would want (either here or send to ryhe@aol.com).
    Bob
  5. #15
    Mfi
    The exhaust from the thermostat just vents into the engine compartment. I will look for the sheetmetal.
  6. #16
    MFI sheet metal
    I found this past week a full set of sheet metal in pretty good shape from a 69E. I've already bead blasted and straigtened and think they'll work out fine. If you find your set, maybe one of the others can use.
    Thank you,
    Bob
  1. Is 911 Midnight Auto Supply is about to launch?
    By sithot in forum General Info
    Last Post: 10-09-2013, 02:36 PM
  2. Is 911 Midnight Auto Supply is about to launch?
    By sithot in forum For Sale: 911 Parts
    Last Post: 10-09-2013, 11:11 AM
  3. FS: Custom Long Hood Outline Hat. NLA. Limited Supply.
    By LynnsABCs in forum For Sale: 911 Parts
    Last Post: 04-21-2013, 04:17 PM
  4. Lance Amstrong and our food supply
    By Reza in forum Off Topic
    Last Post: 06-02-2011, 11:48 AM
  5. Antique Auto Supply
    By CurtEgerer in forum Off Topic
    Last Post: 02-25-2009, 01:43 PM
