Results 21 to 30 of 32
Thread: 2.0 911S motor build for my '68, advice?
  1. #21
    Question: Could I take the stock '68 longblock and install S heads and cams and then get the normal Birals reconditioned and put 81mm JE's in there? Machining to head hopefully not required if I did this?
    A stock spec '67/68 S motor with SSI's and a slight displacement bump would be sick.
  2. #22
    Senior Member gtgroupe3's Avatar
    Sep 2006
    MD
    Answer: Yes you can.
    Option #2: Skip the 81mm P, Bore out the Birals to 84mm and use a set of ‘71 T heads (relatively cheap and common). With the money you save on the heads, have the ports enlarged to 36mm.
    Better performance, reliability and would cost about the same.
    Sumner
    Registry Member #970
    1970 914-6
    Adriatic Blue
    1972 911T (vice)
    Gemini Metallic
    1967 911S (vice)
    Slate Grey
  3. #23
    80mm birals can be bored to 84mm?
    All these options are making my brain hurt....
  4. #24
    Aug 2006
    Chicago area
    Fritter, good luck with your project. I will be following your progress. BTW, did you source a spare 2.0L block, keeping your car driveable?
    Not to take this too far off topic, but I want to ask the gurus a question here. Would running 67S heads with a 2.2L displacement affect rev performance? In other words, would the motor not rev to its redline of 7300? I am almost positive that it would not affect it, but thought I would ask for confirmation.
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
  5. #25
    Quote Originally Posted by Fritter
    Bump, can the 80mm biral cylinders be bored to 84mm?
  6. #26
    Pretty sure they cannot. Cheaper to buy 84s, as-is.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
  7. #27
    Sep 2006
    MD
    Since I am not a proper tech and cannot confirm or support the statement based on my own skill sets. I will say that mine are bored out to 85 mm.
    Not that someone will allude to or question the skills of my engine builder; I can also post some pictures of the 910, 907 & 935 (Kremer) engines (e.g., engine porn) in his shop.
    I would think the owners of these somewhat more valuable pieces of history trust in his abilities may speak to his skill and knowledge a bit more succinctly than I may.
    Sumner
    Sumner
    1970 914-6
    Adriatic Blue
    1972 911T (vice)
    Gemini Metallic
    1967 911S (vice)
    Slate Grey
  8. #28
    Quote Originally Posted by 305966S
    Sumner
    I knew 84mm could be bored to 85mm, but not 80mm. Very interesting!
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
  9. #29
    80 can be safely bored to 81, 84 to 86 or so.
    80s cannot be bored to 84 or more, the design is different.
  10. #30
    Quote Originally Posted by 304065
    Is this a typo? They either can or cannot..
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
  1. 911S / Turbo Build
    By craighardy in forum General Info
    Last Post: 09-15-2018, 05:08 AM
  2. Advice on flat towing my '75 911S
    By davewadd in forum Technical Info
    Last Post: 01-22-2012, 09:48 PM
  3. Advice on 67 911S Value
    By PSportoVeloce in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 08-10-2009, 10:31 PM
  4. Build ideas for 1967 911S Targa R-style
    By ErichW in forum General Info
    Last Post: 09-07-2005, 10:28 AM
  5. Looking at a 72' 911S and need advice
    By rzepko6194 in forum General Info
    Last Post: 12-06-2004, 06:11 AM
