Results 1 to 10 of 16
Thread: 901 Transmission & 210+ HP
    Jun 2003
    Bend, Oregon
    I'm getting ready to put my '67 back on the road after body & paint work. The engine has been built to 2.7 specs and will be sporting a new set of PMO's. With the Webers, it produced 210+ HP. When I got the car it had the original 901 rebuilt as a 4-speed in the conventional H pattern. I prefer a 5-speed and I have a 901 on hand and a 915 on hand, intending to install the 901.
    My questions are: Is the 901 robust enough to handle the engine output? If I installed a 915 instead, what complications will I have to deal with?
    Thanks for the help.
    JohnA
    John,
    I had a 914/6 with a High Compression 3.0 with 964 cams, probably good for 210-220 HP, ran with a 901 w/o problems, just gotta be careful in first gear is all. Sound like a great car.
    Phil
    Like Phil said, keep your foot out of it in 1st and you should have no problems ... except for blazing tires
    -Marco
    TLG Auto: Website
    stick with the 4 speed good enough for the 930
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
    If you don't do smokey tire burnouts, you'll be fine.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Jun 2003
    Bend, Oregon
    Quote Originally Posted by boxster03
    Funny you would say that. The P.O. converted to a 4-speed because he wanted to get first gear off of the weaker reverse spindle, similar to the 930. I think that's probably OK for hill climbs and auto-x, but when I run at Portland Intl. Raceway I feel like I could use more top-end on the straights. Also the 5-speed has shorter gears two through four.
    The engine has 930 cams though - I've don't know if that's a good thing or not.
    JohnA
    IMO my 901 5 speed has a too short 1st a too tall 2nd and 5th but 3rd and
    4th are just right.
    John,
    You don't want 930 cams in a NA motor, you don't even really want them in a turbo motor.
    Phil
    Jan 2003
    West Sussex and The Scottish Borders
    210 etc
    With 210 going through a 901 the weakest point would be the clutch. A standard clutch will burn out if you try anything fancy off the line. Think about a comp clutch.
    Strengthen the 901 (side plate and int plate), good clutch, no burnouts (no Porsche tranny drivetrain that) and you should have no problems.
    I have more HP than that and have never had a problem.
    Juan - Member # 321
    Ft. Lauderdale
    Klub Sport Champion
    Rolex Endurance Champion
    HSR Sprint Champion
    PCA Club Race Champion
  1. Transmission help
    By plumber in forum Technical Info
    Last Post: 01-02-2012, 02:52 PM
  2. WTB: Transmission carrier/mount for 911 (series) transmission
    By PeterM1965 in forum For Sale: 911 Parts
    Last Post: 07-02-2011, 08:16 PM
  3. 901 transmission $350
    By Dmill in forum For Sale: 911 Parts
    Last Post: 05-23-2011, 04:19 AM
  4. 911/01 transmission
    By EARLY911ZOO in forum Technical Info
    Last Post: 09-19-2008, 06:50 AM
  5. WTB: '65-'69 Transmission
    Last Post: 06-11-2006, 05:55 PM
