Results 1 to 10 of 12
Thread: 2.2 rod bolts?
    2.2 rod bolts?
    Anyone know if there is a supplier of high strength rod bolts for the 2.2 engines similar to the 2.0 and 2.4 available thru (?) ARP? My understanding (maybe incorrect) is that the 2.2 rod bolts are unique. For use in stock rods.
    Info appreciated
    thanks
    Chip
    Call Henry at Supertec - I believe he modifies the 2.2 rod slightly to be able to use an ARP bolt for the 928.
    Regards,
    Andrew M
    Quote Originally Posted by andrew15
    Regards,
    Andrew M
    <aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa a>
    yep.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Talking 2.2 rod bolts
    thx very much guys - this is just what I was looking for!
    btw Kenik - what's the status on your motor? I'm very interested in how it runs with the cams you described. Also, are you running MFI, and if so, what are you doing to the pump?
    regards
    Chip
    JE is pretty much killing me with tardiness on the pistons. They still aren't done and Henry doesn't know why. Admittedly, my heads are whack-o one off dome profiles, so I am sure that is a major contributor, but I am getting a little frustrated with JE and their reputation as being a "Custom" piston builder...my eye!
    BTW, yes, MFI. I am staring at my pump as I type. I will send one of my two '69S pumps off to Gus for rebuild.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Kenikh,
    If JE doesn't come through ROSS is a real good alturnative...
    http://www.rosspistons.com/auto_cust...cat=64&item=14
    Luck with the motor bud,
    Cheers,
    Its Nascar season. Always buy your JE pistons right after the final Cup race. EBS might have a set in stock, but dealing with JE during race months... forget it.
    Bill Woods
    S Registry #1005
    Nov 2002
    Fremont, CA
    Actually you just mill down the 2.2 rod and ream to a accept an ARP 2.4/2.7/3.0 (10mm) bolt.
    scott kinder
    kindersport@gmail.com
    Registry #614
    Quote Originally Posted by kenikh
    Hi Kenik,
    what specifications you're looking for?
    #rennfrog
    Completely custom; the cylinder heads are 1969S that were turned to a custom profile. They have much larger dome volume than stock. JE has the heads now to pattern the custom pistons from them.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
  1. FS: SWB Eye Bolts
    By juche_namja in forum For Sale: 911 Parts
    Last Post: 10-24-2014, 07:40 AM
  2. FS: eye bolts early
    Last Post: 04-29-2012, 08:10 PM
  3. FS: New in box - 2.0L ARP Rod Bolts
    By kenikh in forum For Sale: 911 Parts
    Last Post: 07-01-2009, 12:17 PM
  4. 65' Hinge bolts
    By rcnagel in forum Technical Info
    Last Post: 05-30-2009, 10:54 PM
  5. CV bolts
    By cmcfaul in forum Technical Info
    Last Post: 04-10-2007, 12:36 PM
