Results 1 to 9 of 9
Thread: How to determine original Durant round side mirror?
    Senior Member sam71TargaS's Avatar
    Aug 2006
    Colorado
    Okay so another rookie restoration question...how can you determine if you have an original Durant round side mirror? I am missing mine and looking for a replacement, I was told that it has a "Made in Germany" stamp on the housing???
    Sam
    PS - Be prepared for many more of these rookie questions....
    Aug 2003
    Van Nuys, Ca
    Made in Germany stamp: so do the reproduction ones out there! the weight of a real durant should be heavier than the repro- but if you don't have both side by side.....
    there are others here that can probably point out more differences
    Member #755
    Conda Green 70 911S
    70 black 914-6 3.2
    70 911 "Speedster" project
    "74 IROC" tribute Jade Green RSR
    Nov 2003
    Sydney
    Sam,
    Could you pls send me that pic of your paint tag.
    Cheers,
    Dennis.
    S Registry member 536
    Mar 2004
    Castro Valley, Ca.
    this is an original mirror for SWB (actually from '60 - '67) I *think* the logo is the same for the LWB cars. these are either being "repopped" or the original manufacturer has retooled. the stars on the current offering are smaller and grouped differently. i don't have an example to photograph for comparison purposes. they both indicate Made in Germany.
    HTH
    best
    jerry
    Durant
    Jerry is right about the logos being the same for LWB cars. Here is the logo on my original. Also, a photo of one I bought from Stoddard's a couple of years ago...looks the same to me, but engraving is somewhat deeper. Maybe just age. Also, I think you can get a repro for much less$ from Performance Products. Goood luck.
    Lee
    FWIW
    I have never found a repro mirror to feel as smooth as an original when one runs ones finger around the rim. The repros always feel a bit rough!
    Hope this helps
    Chris Parte
    731
    chineese steel
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
    I don't know about others' experience with the repops but when I installed the one I bought from Performance Products I found it wouldn't articulate enough to do what it's supposed to, i.e. show me upcoming traffic while I'm in the driving position. I just couldn't get it into the right position. I've since bought an original from Stoddard. Go figure.
    NickR
    Senior Member rgrimm's Avatar
    Jan 2006
    Fargo, ND
    What NickR said. I bought mine from Perf Prod and have never really been happy with it.
    One is the adjustment issue. Also, the base seems to be a little wider and doesn't fit on the door the same as the original. You can see it in the way the mirror and gasket line up with the door edge and in trying to get a wrench on the nuts to tighten the mirror to the door.
    Roger
    68 Sand Beige 911 Coupe #11830091
    84 Moss Green 911 Carrera
  1. FS: Excellent Original Large Round Durant Driver Door Mirror 69-72
    By dporsche74 in forum For Sale: 911 Parts
    Last Post: 01-15-2014, 10:54 AM
  2. WTB: Large 5" Round Side Mirror Plastic Retaining Ring
    By SteveG in forum For Sale: 911 Parts
    Last Post: 01-03-2011, 12:22 PM
  3. Wanted reflective mirror for Large Durant side mirror 71
    By aporschaguy in forum For Sale: 911 Parts
    Last Post: 12-02-2010, 04:26 AM
  4. WTB: SWB small round door mirror, factory Durant
    By Reza in forum For Sale: 911 Parts
    Last Post: 10-31-2010, 06:53 PM
  5. Fs: Original Large Round Durant
    Last Post: 09-13-2008, 08:20 PM
