Results 1 to 10 of 10
Thread: Trunk stuck, Help.
    Trunk stuck, Help.
    Oh boy, this is a real problem. Just wanted to get my 71S going again but the front trunk is stuck closed. The battery is drained and I can't get to it to start the darned thing.
    It's a T handle and I tried pulling hard but nothing, also tried having someone pull up on the hood while I pulled the T. Nothing. It seems welded in place and does not move at all. This really is a bitch. Any ideas out there?
    Tom
    Apr 2004
    35,000 ft
    the one thing
    I can think of is to push down on the trunk, while trying to pull on the handle, this will take the stress of the latch.
    -Lewis
    Tom:
    I recently had this problem on a 73. I ended up pulling out the rubber seal between the hood and bumper and the 10 mm bolts holding the latch plate can be accessed to loosen the latch. You can then push it sideways to release the hood. Getting these latches adjusted so that they lock the hood down but also release it is a little tricky.
    In my case, the male hood latch was hanging up on the bottom opening of the female latch mechanism below the movable catch which holds the hood in place. Good alignment and getting the correct initial setting of the wire-to-latch, plus the correct depth of the male pin are all necessary for a good working solution.
    Gib Bosworth
    R Gruppe #18
    Early S Reg. #434
    Thanks for the info guys. So far no luck. I was just told that perhaps the seal, the rubber gasket in front, is sticking up too far and not letting the hood down enough. The suggestion was to try to pull or push the gasket down then push up and down on the corners of the hood, bounce it. What do you all think? I'll give it a try in the morning. I'm shot.
    Tom
    Jun 2003
    Toronto
    Same thing happened to me many years ago, fortunatly the batteries were good and I could drive the car. I simply drove the car down a bumpy road while pulling on the hood release, the hood popped up in no time. I guess you charge the batteries through the cigarette lighter receptacle using one of those battery maintainers, it will take a long time though.
    Rudy
    Rudy, I really like your idea....
    I when I started my restoration and had the gas tank removed I closed the trunk lid and heard a clunk. Didn't think about it much until I tried to open the hood and it wouldn't unlatch. I fussed with it for some time until I crawled up through the tank opening and forced the latch open. What had happened was the back plate of the latch had fallen off and the cable would not release anything.
    Porsche had designed it to open if the cable broke but not if the back plate works loose. A failure mode not considered I guess.
    Had my tank not been out I am not sure how I could have got in.
    1970 911S Targa
    On the road again soon.
    Mar 2006
    Louisville KY
    What I did on my 914 which I believe is close to the way my 66 911 is remove the front bumper and there might be a hole in ftont of the latch you could get a long screwdriver in and release the latch
    Oct 2004
    SW Suburbs of Chicago
    Thank you, thank you, thank you! Twisting the cable counter-clockwise bought more opening in the receiver and one good rubber-mallet whap on a flat pry-bar against the plunger popped it open. I love this forum!
    Mike O'Meara
    Reg #1043
    72 911T
    56,59 356s gone
    67,68 912s gone
    on my '73, the dig. lighter is off when the key is off
    I guess we need to either carry a 10mm socket in the glove box (not in the tool kit in the trurk!) when traveling - or else upgrade to a 1074 or later car...
  1. 915 trans stuck
    By Strato 102 in forum Technical Info
    Last Post: 07-31-2011, 10:47 AM
  2. MFI Stuck or other malidies?
    Last Post: 05-16-2009, 03:17 PM
  3. Stuck Glove Box
    By Edwin Ek in forum Technical Info
    Last Post: 06-06-2005, 05:14 PM
  4. Stuck !
    By John Fusco in forum Technical Info
    Last Post: 08-09-2004, 12:37 PM
  5. 915 stuck in gear(s)
    By Burzel55 in forum Technical Info
    Last Post: 06-12-2004, 08:34 AM
