Results 1 to 8 of 8
Thread: Need corner balance help...
    Senior Member Homemade 911's Avatar
    Dec 2002
    China Lake - Third Rock From The Sun
    All,
    Any ideas on who I could talk to about getting my '68 911 race car corner balanced?
    I live about 2.5hrs northeast of L.A....so going anywhere in L.A., or further south to San Diego, (or anywhere else within reach of a "day's tow") is not a problem.
    Anyone? any recommendations? suggestions?
    Thanks - and Happy Holidays to all
    cheers
    Thom Kuby
    And there-ya go...
    West End
    Darren Nishimura at West End is the VERY BEST,
    In Torrance. 310-808-9233. Tell him Stacy sent you. He's done ALL my cars; great guy, fair, does all the work himself, and used to do all the Classic car work at Johnsons.
    Bahia Red '72 911S
    Meerblau PTS 2019 Speedster
    ES #333
    Dec 2002
    Gracias...
    That's great, guys, thanks...
    No...I hadn't seen that Registry resource page - with this group, I prolly shudda known something like that was out there...
    Again, Thanks and Happy Holidays to all
    cheers
    Thom Kuby
    I've had wonderful service from Steve Alarcon as well.
    Assuming we're talking about the same thing, I've also done 2 cars myself. What I did may not have been as thorough as you need, but I used a friend's wheel scale and just tweaked the front torsion bar adjustments to get the front and rear side-to-side weights equal (with a person in the driver's seat) . It takes me about 30 minutes including all the fumbling, assuming the ride heights are about right to begin with.
    The wheel scale was a very simple device that "lifts" the wheel by hooking under the rim at 12:00. You don't even jack the car up. I don't know where one would buy one of these things today, but I suspect any racer's shop would have one.
    Lee
    Lee
    You may be referring to the hydraulic weight load checker sold by Speedway Motors.
    You can get add'l info here
    If you use this, I suggest fabricating a block conforming to the radius of the wheel to prevent the lift device from digging into the wheel (undesireable for Fuchs).
    Hope this helps,
    Sherwood
    That's the one! And yes, I made up a stiff pad to protect the wheel.
    Lee
  1. SWB Alignment and Corner Balance Complete!
    By 304065 in forum Technical Info
    Last Post: 05-12-2022, 04:29 PM
  2. Brake balance
    By Tomas lopez in forum Technical Info
    Last Post: 05-16-2011, 08:26 PM
  3. Crank Pulley Balance - Potential Vibration
    By richemj in forum Technical Info
    Last Post: 01-10-2009, 01:38 PM
  4. Corner Balance and Alignment?
    By A.T. in forum Technical Info
    Last Post: 06-20-2007, 09:11 PM
  5. Early 911S brake balance
    By Plays with Cars in forum Technical Info
    Last Post: 11-04-2002, 10:37 AM
