Results 1 to 7 of 7
Thread: Anyone know these HE's?
    Question Anyone know these HE's?
    Sorry I had to shrink the pics down so much to meet the max requirements.
    14-6 maybe??? Just a wild guess.
    Triad?
    I havn't seen any in a while so I don't remember for sure. They might be Triad. The main problem was weight as was mentioned above.
    Bobby
    71' Olive 2.2E Targa / Early S #491
    I've always considered the glass to be half full...that is until I reached middle age and realized that it is actually half empty.
    Gee, I don't know, they aren't any heavier than stock, they just use the bends for heat rather than include the straights. OK for SoCal where a little heat is needed in the winter and some for the MFI t-stat. I'll use them, just was curious where they might have come from.
    Card carryin' member! mjmoran's Avatar
    Aug 2003
    Triad
    Zeke,
    Found them in an add from an 83 Pano. Here is the claim by the add:
    0-60 times reduced by full second!
    10-20 deg lower temp
    true equal length header system specifically designed for larger engine displacement. Not randon length design as the original factory
    thicker guage steel than stock and aluminized coating
    27 lbs lighter than stock
    yada yada yada...
    Oh yeah...only legal for track use in CA!
    Tschüß
    Michael
    72 911S Coupe, Sepia Brown
    Thanks. They don't seem 27 lbs. lighter.
    Aug 2003
    I think they are compairing to the SC/Carrera set up. They seem to be designed for them.
    Michael
