Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: 1989 3.2 into 1969 911S??
  1. #11
    Steve - what about using the 901. This will be a street car only and I am not abusive on the gears. As this car is a true S I am trying not to change everything. In fact even changing the oil cooler bothers me a bit unless I can do it in a reversible manner.
    Bill
    1969 911S - slightly bastardized
    By the way, what has Porsche been doing for the last 30 years?
  2. #12
    Quote Originally Posted by zcat3
    I would not use any 3.2 with the 901.
    Although you mentioned that you are kind to transmissions, I have to guess that you plan on stepping on the throttle of a 3.2-powered '69 911 once in a while (otherwise why do it, yes?), and the 901 is simply overstressed with that amount of torque.
    I would use a later 915 with close ratio gears (2nd thru 5th) and LSD. That makes a car like this VERY quick,.....
    Steve Weiner
    Rennsport Systems
    Portland Oregon
    503.244.0990
  3. #13
    O.K. Steve - that being the case what year 915 should I be looking for? Do I need to also change all of the shift mechanism parts to do this? Will the speedo and tach work with a 915?
    Bill
  4. #14
    If I was doing this, I would use an SC or Carrera 915, shifter, and shift shaft.
    You will need to run a pair of wires into the tunnel for the electronic speedo that you must use. I send the speedo to North Hollywood Speedo so they can put the early face & needle on that thing.
    Tach compatibilty has more to do with the engine management in use. If you use the Motronic on the 3.2, I'd use a Carrera tach and have that fitted with the early face and needle if you want things to appear original.
    Steve Weiner
    Rennsport Systems
    Portland Oregon
    503.244.0990
  1. Porsche 911S Owners Manual 1969 911S 2.0
    By 72targa in forum For Sale: 911 Parts
    Last Post: 03-19-2021, 07:29 PM
  2. Replies: 4
    Last Post: 03-03-2014, 11:45 PM
  3. Fs: 1969 911s
    By wsf80 in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 02-05-2013, 11:54 AM
  4. Pending Russo & Steele Auctions of 1967 911S & 1969 911S
    By 72targa in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 01-25-2011, 11:11 AM
