Thread: 901 trans ? on gears
    Dec 2002
    71236 Brush Rd. Niles, Mi. 49120
    Does someone know if I can take a 901 trans "V" 5th gear and invert it then put it in the location of 4th gear? Would this work to be the same as a"R" 4th gear? I'm building a short box for my 911s. Right now I have the parts to make a gear box with A-1st, F-2nd, KA 3rd (filped-ZD 5th), R-4th (fliped V), X-5th.
    Grover #53
    1967,911-S
    Suffolk, VA
    I don't see why this would not work. But remember that all gears are in pairs - one on the output shaft and one on the pinion shaft. They must remain together.
    Citation F1000 on the way
    Other Early 911/912/914
    I ran a flipped 5th in the 3rd postition with no apparent problems. When I looked at the gear stacks and observe the backwards orientation of the flipped gear's teeth, it looked strange to me.
    Now, you're gonna have 2 sets in there backwards. I guess it doesn't make any difference since mine and others worked fine. But you have to ask why they put them all together with the same tooth slant from the beginning.
    Dec 2002
    Zeke
    Thank You for you info. If the 3rd and 4th are both fipped does it put extra strane on any of the bearing? So when the gears teeth are opposite the other 2 gears in side the box would it make more turbulence inside the box and cause problems?
    Grover #53
    1967,911-S
    I can't answer those questions. The 901 guru is John at Otto's in Venice, CA. I think if you need to buy a gear or something for your project, he would be generous with his advice. Listen to what John says.
    short cut
    to Otto's .
    Shawn.
    67 coupe roller
    99 M96 2.5 litre
    early911s reg 447
    R Gruppe 399
  1. Replies: 2
    Last Post: 12-03-2015, 07:16 PM
  2. WTB: Gears - K, Q and V
    By eronbo in forum For Sale: 911 Parts
    Last Post: 05-07-2013, 07:56 PM
  3. Replies: 0
    Last Post: 01-14-2013, 07:10 AM
  4. Replies: 0
    Last Post: 12-03-2012, 05:04 PM
  5. LAST STASH OF VINTAGE EARLY 911 PARTS. NOS trans gears, seals, cams, S rods, etc.
    By velocejoe in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
