Results 1 to 7 of 7
Thread: How do I tell E or S cams?
    Guys,
    I found a guy with a box of cams. They appear to be new. Problem is, no one seems to know what cams we're looking at. They have numbers on the side that seem to correspond to the part number in the parts book except that the last two digits don't match. Can I determine cam type by these numbers on the side. between the lobes? If not, where do I look? If I wanted E or S cams to put in the mfi 2.7 I am building based on my 73 2.4 mfi T, what numbers should I be looking for? Where should I look?
    Thanks for the help
    The Capitalist Roader
    73 MFI T coupe
    73.5 T Targa
    73 Sporto S Coupe
    Measure the intake lobe size as defined in Wayne' engine book
    S: 37.30 mm
    E: 36.58 mm
    Thanks for the help. I'll check my copy at home tonight.
    Thumbs up
    Thanks Nick !
    Between the casting #'s and anything else that might be stamped on those cams... NOTHING tells you what they are.
    Feb 2003
    Los Angeles
    S cams
    Hello John,
    Did you buy the whole box of cams? Or does your guy have more S cams for sale?
    I am looking for a pair of S cams.
    Bert Jayasekera
    1970 911T - Tangerine Orange
    Early 911S Registry #494
    R Gruppe #167
    and I need a single right hand MFI S cam for a customer who ran his engine for over 200 miles with a broken tappet adjuster.
    Guys,
    I am still trying to figure out what I am looking at. If I understand the previous post, the only way to tell is by the cam lift. If that is the case, I need to find a print out of all the different dimensions so I can tell the E's from the S's from the CIS cams. So I guess the best thing to do is to inventory the whole lot and figure out what's what.
    When I get a chance, I will let you know what I find.
  1. What cams are these?
    By Alex65 in forum Technical Info
    Last Post: 03-24-2014, 02:01 AM
  2. FS 911 E-Cams
    By Erik@GBox in forum For Sale: 911 Parts
    Last Post: 09-10-2009, 12:39 PM
  3. Trying to ID cams.
    By rngpc in forum Technical Info
    Last Post: 06-13-2007, 07:10 PM
  4. 906 Cams
    By ErVikingo in forum For Sale: 911 Parts
    Last Post: 02-20-2007, 05:10 AM
  5. Help ID cams 901.105.139.OR, 901.105.110 OR
    By MarkS in forum Technical Info
    Last Post: 01-19-2007, 03:33 PM
