Results 21 to 30 of 31
Thread: Under bumper fog lights, '73 RS
  1. #21
    Sep 2006
    San Francisco
    My car had these lights originally and I've tried unsuccessfully to source the brackets. I did design one in CAD and have 3D printed a plastic version just to check for sizing. I'm going solely off of Eric's image with the ruler, which is a huge help, but the camera angle is skewed so it's really tough to get accurate dimensions. But I think I can get it close. The easiest approach would be to get an actual bracket and either scan it or take all the critical measurements. Then it would be possible to fabricate something close.
    And I'm only considering the "main" bracket at this point. Cees may be correct that there is another one that sandwiches the lip of the spoiler, but I thought it was just bolted through the lip.
    Jeff Jensen
  2. #22
    The Netherlands
    Thanks Jim and Jeff, with the part numbers in hand I will check with Freisinger. See if they have something.
    Regards,
    Cees
  3. #23
    Sep 2006
    San Francisco
    Quote Originally Posted by fourteenten View Post
    Regards,
    Cees
    Great, let us know what you find.
    Jeff Jensen
  4. #24
    The Netherlands
    Under bumper fog light bracket
    Ordered and received the brackets from Freisinger. See pictures, priced at €120,-/each plus VAT, plus UPS shipping. And that is only for one bracket. The swivel is another €40,-..
    Regards,
    Cees
  5. #25
    Sep 2006
    San Francisco
    That's awesome Cees, thanks for following up. Going to order a set.
    Jeff Jensen
  6. #26
    Jan 2019
    SF Bay Area
    Quote Originally Posted by mobius911 View Post
    yes, thanks Cees for the follow up and info! @mobius, I'm interested in a set as well, so if you be interested in splitting the shipping from Germany, let's chat (I'm just south of SF).
    Member #3857
    '70 911 2.7
  7. #27
    Sep 2006
    San Francisco
    Just wanted to follow up after receiving the brackets from Freisinger (and I did order another pair for Iz7w). Cees, seems like you immediately thought of Freisinger for this. What other unobtanium tidbits do they have?
    Anybody have dimensions for the mounting location, or this more of a "look at some photos and do it by eye" kind of thing? And thanks again Cees for the info!
    Jeff Jensen
  8. #28
    Senior Member HughH's Avatar
    Dec 2004
    Melbourne Australia
    Jeff
    Check the underside of the bottom of your spoiler.
    My (genuine steel 73S) spoiler has a hole in the bottom edge on each side about in line with the middle of the horn grill. I presume they are for the low mounted lights
    Hugh Hodges
    73 911E
    Melbourne Australia
    Foundation Member #005
    Early S Registry #776
  9. #29
    The Netherlands
    Hi Jeff,
    Freisinger is the last resort finding these special parts. If they don't have it, probably no one else either. Just give then a part number and you will hear quickly if they have it.
    If you have an original Porsche RS GFK spoiler then there are already two mounting holes each side. You can't miss them.
    Cees
  10. #30
    Lightbulb
    I believe Hugh is correct....
    The spoiler on my car has'm (blue)
    And my factory replacement has'm (light ivory)
    You can see there is a sheet metal support on the inside that the holes straddle...
    Hope this helps...
    cm
  1. FS: LWB Under the Bumper Hella 139 Lights
    By Allen Henderson in forum For Sale: 911 Parts
    Last Post: 01-23-2014, 05:37 PM
  2. WTB: Below the Bumper Lights
    By luke-44 in forum For Sale: 911 Parts
    Last Post: 01-11-2014, 10:48 PM
  3. FS: Hella 169 Below bumper lights
    By mfitton in forum For Sale: 911 Parts
    Last Post: 08-28-2013, 05:17 AM
  4. 67 bumper lights and rear fog
    By LeonardZ in forum Technical Info
    Last Post: 12-28-2008, 06:52 PM
  5. Replies: 10
    Last Post: 10-18-2006, 01:04 PM
